It is currently Tue Aug 19, 2025 3:38 am
PostPosted: Mon Mar 11, 2013 8:23 pm
Hi all, first time post on here although have been reading for quite some time. I'm slowly putting together my 1970 mini k after painting and I was wondering what sealant goes between the rear windows hinge and the body? They had a black mastic type substance under them when removed, which I assume was from factory. Would sikaflex do the job here?Any advice/input would be much appreciated.
Sean
1970 mini k1100
PostPosted: Mon Mar 11, 2013 8:37 pm
I would not use Sikoflex , it is a glue
when I put mine together I used black windscreen sealant
more a waterproof gap sealer than glue
Mark
PostPosted: Mon Mar 11, 2013 8:40 pm
Yes +1 for windscreen sealant
Although many years ago I did manage to find a similar rubbery substance for when I restored my Cooper S
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Mar 11, 2013 8:46 pm
Mark
Thanks for the reply, Mark. I thought sikaflex was a windscreen sealer?
1970 mini k1100
PostPosted: Mon Mar 11, 2013 8:51 pm
Mark
Sikaflex is the manufacturer/brand . They make heaps of different types of glues and sealants.
They do make a windscreen sealant. Basicly it looks the same as the normal urethane sealant, but it doesnt completely set.
Dusk Blue
1964 850
PostPosted: Mon Mar 11, 2013 8:56 pm
I think the original stuff was a butain rubber stuff (don't know if I spelt that right) When I put mine together , no one knew what I was talking about .
wind screen sealant sets but does not go hard , not untill 40 years :D
PostPosted: Mon Mar 11, 2013 8:58 pm
MrFail wrote:
The original sealant doesn't appear to have set, that's why I thought another mastic sealant (like sikaflex windscreen sealant) would be suitable.
1970 mini k1100
PostPosted: Mon Mar 11, 2013 9:07 pm
Sounds like the sikaflex windsreen sealant is the sfuff you need
Mark
PostPosted: Mon Mar 11, 2013 9:48 pm
Original sealant is a butyl mastic, it is available from Supercrap and all the other suspects.
You can get it in grey or black. Brand unimportant, it's all the same.
Sikaflex 291 etc is a gap sealant but it sets, IMO it's not what you want to seal window glass into a rubber. These types are more used to bond glass onto the body on late model cars.
PostPosted: Mon Mar 11, 2013 10:03 pm
I thought windscreen sealant was just black silicone.
Thats what it has always appeared to me to be when I have used them.
PostPosted: Mon Mar 11, 2013 10:12 pm
Nope, butyl mastic is not silicone.
PostPosted: Tue Mar 12, 2013 9:49 am
Has anyone had an issue with the black sealer used on the window rubbers turning the chrome filler strip brown?
I had a front and rear screen put in by a professional installer who insisted on using the black sealer under the rubber. Two weeks later the filler strip was a brown colour.
Thought it might have sun damage but another local mini person had had the same thing done recently and his has just turned brownish as well?????
Dave K.
PostPosted: Tue Mar 12, 2013 10:23 am
There shouldn't really be any sealant in the channel where the chrome locking strip goes. However most rubber contains plasticiser which can migrate into other plastics and discolour them, it might just be coming from the seal itself. Its a very common problem with car tyres on garage floor coatings.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Tue Mar 12, 2013 11:29 am
Maybe it's just me...but I've never used any kind of sealant either between glass and rubber, or rubber and body, and I've never had a leak. Our current car has some kinda black crap in the front screen, and it runs down the dash rail on a hot day :x
PostPosted: Tue Mar 12, 2013 1:08 pm
The 'chrome' filler strip always seems to turn brown eventually so I've just used the black version which I prefer anyway.
Users browsing this forum: No registered users and 316 guests
