It is currently Sat Jul 19, 2025 12:31 am
 Post subject: Cam Follower Destruction
PostPosted: Tue May 05, 2015 2:07 pm
Oh dear, worry, worry...
Hi All,
I don't have to say much. Please grind your Cam Followers.....
He thought he was putting the best of everything in it, this is the result after a few thousand kilometres. :cry:
These cam followers weren't Kent followers, they were a lightened follower that most people use in their motors.
Graham Russell
PostPosted: Tue May 05, 2015 2:25 pm
Nasty, bet that was rattling a bit.
PostPosted: Tue May 05, 2015 4:31 pm
That is horrific!
PostPosted: Tue May 05, 2015 4:32 pm
Nothing five minutes with some emery paper wouldn't fix. :roll:
Anyway, Graham, it's not all bad news. At least it wasn't one of your cams that was destroyed. :)
PostPosted: Tue May 05, 2015 5:03 pm
bugga :cry:
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Tue May 05, 2015 6:24 pm
Needs more zinc in the oil.
PostPosted: Tue May 05, 2015 7:01 pm
IMO it's a good idea to check your valve lift figures from time to time with a dial gauge. If the lift starts going south, and you are getting mucho stuff on the sump plug magnet, you may have a problem....
[edit] I wore a Camtech VP3 cam down once, valve lift (1.5 rockers) dropped from .490" to .270"...!
Last edited by drmini in aust on Tue May 05, 2015 8:29 pm, edited 1 time in total.
PostPosted: Tue May 05, 2015 8:16 pm
Yikes. Mick summed it up pretty well (Horrific).
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Tue May 05, 2015 9:08 pm
That's pretty much my worst nightmare in pictures... :shock:
cheers,
Jacob
PostPosted: Wed May 06, 2015 8:49 am
An additional question sort of in the same ballpark.... I see mentioned that a hardness of 55-57 Rockwell Hardness is recommended for lifters. Does a reground cam need to be heat treated to match this or slightly exceed this figure- but whilst asking this, i doubt hardness played any key factor in this scenario.. ouch
PostPosted: Wed May 06, 2015 9:15 am
What do you think post mortem is Graham?
No radius on followers and no rotation, or hardness issues as well?
Were the spring pressures OTT?
cheers Ben
The formula for the length of a piece of string is simple: Twice as long as from one end to the centre!
PostPosted: Wed May 06, 2015 10:48 am
As Harvey Keitel said "someone has to pay"
PostPosted: Wed May 06, 2015 11:02 am
The surface looks like it shatters like glass...
PostPosted: Wed May 06, 2015 1:13 pm
Surface is white iron, hard as. (lifters are cast iron, chill cast on the end).
PostPosted: Wed May 06, 2015 7:19 pm
Hi Ben
Just grind you followers can save a lot of tears.
Graham Russell
