It is currently Fri Aug 15, 2025 1:11 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 86, 87, 88, 89, 90, 91, 92 ... 568  Next
PostPosted: Mon Oct 05, 2009 6:37 pm
Argued with the carby........Again :roll:
PostPosted: Mon Oct 05, 2009 7:07 pm
forgot Yesterday I also cleaned up the HIF44 card and also replaced the filter
Today I contemplated taking the pinion out of the Remote change box but waited for a few comments from here. So I cleaned up a Binnical that one of our good friends on here sent me and fitted a Speedo and Oil Pressure and water temp Gauges. Looks brilliant once the glass and bezzles were clean again. Just wish the Oil gauge face was blacker thou.
Ended up taking the Remote change over to Dr Mini's and we are now going to clean that up and put it on the block
PostPosted: Mon Oct 05, 2009 7:16 pm
He means use the 4 synchro Mini K box not the 3 synchro Moke?/Deluxe? one... :lol:
PostPosted: Mon Oct 05, 2009 8:06 pm
Back from 7 weeks OS so washed the red dust off put the battery back in fired it up and just sat and listened to to exhaust while it warmed up. Out of rego whilst I was away so down to RTA next Sat.
" I'll show you mine if you show me your's"
PostPosted: Tue Oct 06, 2009 5:14 pm
Its school holidays and as I'm a teacher it means I have time off to play with my car. So today I pulled the motor out ready for a rebuild, which wont happen until next month. It took me a while to do because first I pulled the car out of the garage, cleaned the garage, organised my tools, then worked on the car for 20min, had a cuppa and a chat to the neighbour, disconnected everything, went and got a hamburger with a mate, had a beer, played some darts, picked up the engine crane then finally lifted it out. I started at 10:30 and was completely packed up at 4:30. Not a bad days work :lol:
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Oct 06, 2009 5:36 pm
Drove it to work and it RAINED :shock: ARRRRRGGGGGhhh wet Mini, snuck it home between showers an dryed her off with an air hose :D
PostPosted: Tue Oct 06, 2009 10:19 pm
This space for rent
Decided the throttle pedal was getting a bit stiff, so pulled the cable outer off and cleaned the inner and unwound one broken strand back to the pedal. Treated it to a bit of graphite powder and threw it back on and now it's smooooooooth as silk again 8)
PostPosted: Wed Oct 07, 2009 11:24 am
Replaced the throttle cable and throttle return springs . Also honed out the master cylinder so it's super shiny and smooth ready for the kit arriving shortly :D :D :D
PostPosted: Wed Oct 07, 2009 8:32 pm
Cleaned the front and rear suspension parts of my Project car. Removed the bearings in the front and rear swing arms and then picked up a full set of reconditioning kits from Karcraft. Fitted the new bushes in the rear swing arms and reamed them out to fit the new shafts. Used the fantastic how to guide in Ausmini "Radius Arm Rebushing - A How To." Hope to paint the parts over the next few days and then refit the bearings. :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Oct 07, 2009 8:43 pm
Diddled with the SU again..... all went pear shaped ,swore and went inside
PostPosted: Thu Oct 08, 2009 5:54 pm
Put it up on stands.
Let the maintenance begin!
PostPosted: Thu Oct 08, 2009 6:11 pm
Lightened a flywheel for Baxters 850 (um, it's really an 1132 now....)
it's off to GR with the crank & clutch tomorrow for a balance job.
PostPosted: Thu Oct 08, 2009 6:37 pm
Wife had dramas changing gears so a quick inspection seems to make the slave cyl the culprit , so theres tomorrows job sorted ( does it ever stop)
PostPosted: Thu Oct 08, 2009 7:23 pm
Cleaned and degreased both of the sub frames ready to send to the sandblaster tomorrow.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Thu Oct 08, 2009 7:40 pm
cleaned up the twin carbs and started prepping the starter motor and alternator for a coat of paint. Tomorrow I will paint them then start cleaning up the engine bay.
Things left to do:
-get the extractors fixed
-get the tyres sorted
-fit the bonnet straps
-drop the motor off to get rebuilt
-refit the motor
-fit new gauges and binicale
-find new steering column shroud (mk1)
-fit new column, stalk and shroud
the list goes on.....
Ryan Filippi
Minis In The Gong
[email protected]
Users browsing this forum: No registered users and 174 guests
