It is currently Fri Aug 15, 2025 6:39 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 97, 98, 99, 100, 101, 102, 103 ... 568  Next
PostPosted: Sun Nov 08, 2009 9:47 pm
saturday and sunday did the backroads tour around eildon /lima and a whole lot of really good mini roads that we did not know existed a really great weekend
thanks to Peterand Karen Morris of the NEMOG section of VMCi
a totally fun weekend :D :D :D :D :D :D
and for some of the games they invented :twisted: :twisted: :twisted:
PostPosted: Tue Nov 10, 2009 8:31 am
went outside..opended garage..looked at mini....too damb hot..closed garaged...
went inside..
PostPosted: Tue Nov 10, 2009 12:05 pm
Milatsmadmini
went for a drive in the moke in this cloudless mid to high 20's day :)
PostPosted: Tue Nov 10, 2009 1:10 pm
Un-locked my welded up distributor (!!!) put back into car, set timing at 28 degrees total and enjoyed newfound power and willingness to rev...will do until i get a pulsar distributor.
PostPosted: Tue Nov 10, 2009 1:50 pm
new thermostat so hopefully cures my overheating problem
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Tue Nov 10, 2009 2:49 pm
Secondhand pipe bending tool and new circlip pliers cheap from the local markets - score! At the rate I'm going they should come in handy in about 2-3 years from now :lol:
the internet wrote:
Like Audrey Hepburn, almost everybody loves the Mini. The only people who didn't love the Mini were pathetic, empty people.
PostPosted: Tue Nov 10, 2009 7:33 pm
100 Pages 8) well done Everyone :wink:
PostPosted: Tue Nov 10, 2009 10:26 pm
Where are these local markets? Tell me tell me! I'm so broke I need to scrounge for tools
Copper 4 lyfe!
 Post subject: What did I do?
PostPosted: Tue Nov 10, 2009 11:30 pm
Sanded back body filler.... Then sanded back more body filler. Getting closer to painting time...
PostPosted: Wed Nov 11, 2009 7:41 pm
1275LS Project - Removed the fly wheel and clutch yesterday. no timing marks on the fly wheel as the have been ground off????
Did nothing today as I am in Melbourne. Bloody hot down here.. :shock:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Nov 11, 2009 9:06 pm
Took the mini for a drive around town to do some chores, handled the 35degree heat (yes in Ballarat!!) without an issue......unlike it's driver!
Still love the looks and smiles it gets.
So much smoother and responsive with the distributor advance working, just a hint of lumpyness at 2000rpm on cruise with the re13 cam, but MUCH smoother than previously! Now for a properly curved pulsar dizzy......
PostPosted: Wed Nov 11, 2009 10:35 pm
I looked at it and talked about it. :D
PostPosted: Wed Nov 11, 2009 10:56 pm
Gave it a head job... I mean I did a head job.... I mean I :roll:
I got all the spiders out of that head, tanked it and worked the intakes and exhausts. Rim flows due in about a week, then its time to skim and seat the sucker :twisted:
PostPosted: Fri Nov 13, 2009 6:10 pm
Worked on the 'A' panel some more : finished off the repairs to the inner panel - painted the inner with Cold Galvit - ran some seam sealer over the areas that needed it and around the bolt holes as in the original - fitted and clamped the outer in place and started welding - every second 'spot weld' hole and some tacks down the door jamb. Getting late so called it a day - beside I had to let the fires die down :roll:
Dropped some brake lines off to get flared (off the front hubs-connection between cylinders and a couple off the rear wheels as well)
PostPosted: Sat Nov 14, 2009 10:09 pm
Finished off 90% of the A panel and welded up most of the door jamb edge - a second problem with the SIP brand of welders is that the more it is used the speed control circuit heats up and the feed gets faster - so I had to keep stopping and letting it cool down otherwise it blew holes (only small ones :wink: ) Should have it all finished next shift.
Users browsing this forum: No registered users and 208 guests
