It is currently Sat Jul 19, 2025 4:29 pm
PostPosted: Sat Jul 10, 2004 12:13 pm
Don't get me wrong. 1310 or 1380 is the way I want to go, but I know the 1098s were torquier because of a longer stroke.
Here's the plan so far. Lighten and balance the components, crankshaft wedged, buy a lightened flywheel (not the ultralight - I think I do need some weight there). Will fit high lift rockers, belt drive, electronic ignition. I just need advice of the best way to go for torque not being a mechanic.
You're only supposed to blow WHAT off?
PostPosted: Sat Jul 10, 2004 3:25 pm
1098s have good torque, but nothing like what a 1275 or bigger has. The stroke of a 1098 is .096" longer than a 1275, but the bore is a good 6mm less.
To put it in perspective-
Stock Mini 1098 had 60 lb/ft torque
1275 LS, 1100S etc (single carb) had 69 lb/ft torque
1275 Cooper S (twin carb) had 79 lb/ft torque
1380 S I did last Xmas, with a 286 cam and 45 Weber had 106 lb/ft torque on Russell Engineerings engine dyno (measured at crank).
So. I agree with 9YaTaH- 1098 is good, but there's no replacement for displacement! :wink:
