1098s have good torque, but nothing like what a 1275 or bigger has. The stroke of a 1098 is .096" longer than a 1275, but the bore is a good 6mm less.
To put it in perspective-
Stock Mini 1098 had 60 lb/ft torque
1275 LS, 1100S etc (single carb) had 69 lb/ft torque
1275 Cooper S (twin carb) had 79 lb/ft torque
1380 S I did last Xmas, with a 286 cam and 45 Weber had 106 lb/ft torque on Russell Engineerings engine dyno (measured at crank).
So. I agree with 9YaTaH- 1098 is good, but there's no replacement for displacement!
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
