It is currently Tue Aug 05, 2025 3:00 pm
PostPosted: Sun Jan 22, 2006 12:05 pm
ok, but i dont wanna ruin meenis gb, understandably as it isnt a race car. im not going to be pushing it, but i will try and get the discs on there in the next couple of days
Potato
PostPosted: Sun Jan 22, 2006 2:45 pm
meeni wrote:
hey this wont damage my gearbox will it?? cos i dont wanna screw in my car experimenting with stopping.
:? :lol:
Funny farken shite!!!
PostPosted: Sun Jan 22, 2006 5:12 pm
Do yourself a favour Meeni - If you don't get the discs on before you tackle Calder, take all your drums off, blow out the dust, ensure there's no weeping cylinders and contaminated shoes, then put them back on, adjust them properly and bleed out all the old fluid replacing it with new stuff.
Meeni : ..... on a track like calder park, which is a low braking circuit except at the end of the main straight.
Err, yeah! Well I seem to recall another heavy application at the end of the long back straight as well, and a couple of lighter applications going into Turns 2 and 8.
There's dozens of guys racing historic cars on drum brakes (my experience is in a Bugeye Sprite) and there's nothing wrong with drums per se, they need to adjusted properly and regularly, and if you can get some air flow around or through them they'll do an amazing job.
Curly
PostPosted: Sun Jan 22, 2006 5:40 pm
ok, any ideas of what i could do to get better air flow into them? is it as simple as a pipe directing air to them, or something else?
Potato
PostPosted: Sun Jan 22, 2006 10:05 pm
Ducting air from under the car to the inside of the wheels is a good start, but difficult with a pre '65 shell because they don't have the cutouts in the front valance. You can then either strategically remove, or drill ventilation holes in those parts of the backplate that don't have a structural function, then you can replace the cast iron drums with something like the alloy minifin drum or a ribbed cast iron drum that has a greater outer surface area to dissipate the heat. I've even seen ventilation holes drilled in the outer face of the drum around the outside of the hub flange, but I wouldn't recommend that as it may weaken the drum and cause it to fracture :shock:
Curly
PostPosted: Mon Jan 23, 2006 3:38 pm
teh admin God
teh admin God
just fling around the corners with the handbrake?
Surely thats easy enough?
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
PostPosted: Wed Jan 25, 2006 9:01 pm
well they more then went the distance today, was brilliant, had the larry perkins v8 team and the carerra cup cars running with me. was bloody great!!! pics and video will be up soon
Potato
