It is currently Fri Jul 18, 2025 7:04 pm
PostPosted: Mon Jan 16, 2006 9:59 pm
With discs, there is much more weight transfer to the front, but line pressure to the back is still limited to the same as before. So, with less weight, rears can lock up = U lose control.
Fitting 5/8" rear wheel cylinders (Cooper S) instead of the stocko 3/4" ones fixes this problem, usually.:)
PostPosted: Mon Jan 16, 2006 10:37 pm
thanks for the info brickworx and thanks for putting it into terms i understand dr mini in aust. since the rear ones are stuffed they should be right for the amount of time it will take me to save up and replace them(well get them completely redone)
i post news of the phone calls i make tommorrow with costs and what not, for advice.
but any further info now is very helpful
once again thankyou to everyone who has helped me so far on this topic 8) .
PostPosted: Mon Jan 16, 2006 10:48 pm
My advice is get the rears done at the same time...
that way you'll get the full effect of having discs.
otherwise you will have an ok pedal, but not much braking efficiency.
Rears are cheap...
p5095 wheel cylinders
1333 brake shoes.
use these part numbers at non mini shops
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Tue Jan 17, 2006 5:53 am
If the rear drums are worn, any decent brake shop can machine them to 1/32" or 1/16" oversize and supply exchange rebonded shoes radius ground to suit.
Don't use standard shoes with oversized drums- they will run out of adjustment before they are bedded in. :cry:
PostPosted: Tue Jan 17, 2006 8:42 am
just got off the phone with him
disc brakes and everything needed to fit them cost $1400+$500 to have them reconditioned there+$250 to have them fitted there provided they don't need to re-do the brake lines, or something like that.
so that is $2150
i guess i'll ahve to talk to my mechanic and see what he can do for how much.
what exactly does go into reconditioning cooper s disc brakes?
PostPosted: Tue Jan 17, 2006 9:30 am
Woowww $1400 for non recoed discs??? thats expensive!! You can get them brand new for that price! :shock: I think everyone here was assuming you meant brand new.
PostPosted: Tue Jan 17, 2006 9:35 am
i was too :roll: :oops: . thats why i called again today 8) .
PostPosted: Tue Jan 17, 2006 9:37 am
For $1400 i would expect the brakes to be already rebuilt, brand new shiny ones are about 2k and even less if you shop around and second hand discs setups should be no more than half the new price ande if they need rebuilding totally should cost about $500 a set :D
PostPosted: Tue Jan 17, 2006 9:38 am
yeahh damn..
Maxi23 wrote:
I was considering buying the $1500 set from minisport
I'd get those ones, ask your local mechanic how much for fitting... and you'll have some brand new S discs on your mini for under $2k
PostPosted: Tue Jan 17, 2006 9:43 am
cant go past getting a new set from minisport.
I know people on here that have got 2nd handers and ended up costing as much as new ones..
and its really not much more to get the back brakes parts at the same time.. new spaced drums are only around 50 - 60 per side..
 Post subject: Brake shoes rear
PostPosted: Tue Jan 17, 2006 10:27 am
Umm just a quick one,
The rear shoes are not a 1333 like "someone" said, they are a 1332, the 1333 are front shoes (I am sure this was just a typo).... and also make sure that the brakes are on the correct way as there are 4 ways they go and only one is correct....If you need assistance i am sure somone on here has this info, or else we can give it to you.
Anyhows,
Catya round,
Andrew
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
PostPosted: Tue Jan 17, 2006 10:34 am
i think you were reading Docs post about oversize linings after the drums are machined
"any decent brake shop can machine them to 1/32" or 1/16" oversize and supply exchange rebonded shoes radius ground to suit. " :D Thats imperial measurements for those to young to remember
Jon
