It is currently Sat Jul 19, 2025 2:57 am
PostPosted: Fri Aug 27, 2004 12:41 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hey jam "now i'm gonna love you till the heavens start to rain now i'mmmm gonaa love you till the stars fall from the sky for you and i"
PostPosted: Fri Aug 27, 2004 3:50 pm
Anto wrote:
Boondocks? You mean Queanbeyan, right? :lol:
68Delux - I always have that problem with my hydro. But remember, it's a hydro! If you lift the car up yourself first, it doesn't settle as low to the ground and you can fit the jack under.
When I do an oil change, I jack the front of the car up then let it down, only then will my oil tray fit under the sump!
Try driving the LF wheel up onto a housebrick, pointing downhill. Gives you more sump clearance, and also it'll drain out better. 8)
PostPosted: Fri Aug 27, 2004 5:30 pm
for some reason the diamond jack from a 1980's ford falcon is so flat it gets under the Mini with no problems.
There is/was also a cheap 1000kg trolley jack at SuperCrap for $60 (or something close) that gets under there no problems.
PostPosted: Sat Aug 28, 2004 2:46 am
GEEEEZ!!!! i was suggesting carrying a scissor jack in the car.... the trolley jack stays at home :wink:
unless of course you are me - my trolley jack has been in the boot for 3 weeks simply cos i couldnt be bothered getting it out.... gotta take 2 engines out of cars at a friends house but am waiting for a sunny weekend..... :roll:
