Sounds like a Metro cover.
There are some rockers that don't fit in that particular one.
Try it and see.
You may have misunderstood, I already have the alloy one fitted and it seems OK over the rockers. I wanted to know if an original tin rocker cover (which I prefer the look of) would fit over these rockers instead.
The alloy one is pictured below. One problem I do have with the alloy one is that the oil cap contacts the bonnet underside inner panelling. Both are marked from years of rubbing.
