It is currently Tue Aug 05, 2025 9:54 pm
PostPosted: Thu Jan 07, 2010 3:50 pm
Phat Kat wrote:
phillb wrote:
Also I have noticed the oil filler cap of the alloy one has been rubbing on the bracing of the underside of the bonnet.
:?: how curious?:
yeah, the filler cap is in the centre which puts it right where the cross bracing is and it has a monza style flip open cap. Maybe that's not original. It looks pretty tall anyway.
PostPosted: Thu Jan 07, 2010 6:39 pm
Sounds like a Metro cover.
There are some rockers that don't fit in that particular one.
Try it and see.
If they hit on the back, a trick I have used with fitting Corolla rockers is to slot the 2 stud holes in the top forwards about 1.5mm. Then push the cover back. Works fine, on the alloy covers I had (not same as yours).
PostPosted: Thu Jan 07, 2010 9:03 pm
Try it and see.
You may have misunderstood, I already have the alloy one fitted and it seems OK over the rockers. I wanted to know if an original tin rocker cover (which I prefer the look of) would fit over these rockers instead.
The alloy one is pictured below. One problem I do have with the alloy one is that the oil cap contacts the bonnet underside inner panelling. Both are marked from years of rubbing.
PostPosted: Thu Jan 07, 2010 9:23 pm
Yes they will fit OK in a standard Mini rocker cover. :wink:
