It is currently Sun Jul 27, 2025 2:03 pm
PostPosted: Mon Sep 18, 2006 11:14 am
im with the doc on that one, i used sicka flex aswell.
PostPosted: Mon Sep 18, 2006 11:15 am
The rubber on mine is just from a bicycle inner tube....works a treat and has a built in curve.
PostPosted: Mon Sep 18, 2006 11:33 am
Go down to Clark rubber and get some Rubber strip which has a thicker section at the top - when you look at it from the end it looks like the letter 'P'.
Probably cost about $30 - $40 max and looks really good
PostPosted: Mon Sep 18, 2006 11:36 am
I like that idea better. I was in the local rubber shop (oo err) yesterday and it's amazing all the speciality stuff you can get. Also managed to get a generic boot seal off the roll which fits just perfectly.
PostPosted: Mon Sep 18, 2006 12:32 pm
Some older cars eg. VW Beetles use a rubber strip designed for this.
Should be available at yer local rubber shop.
As for Clark Rubber, I was disappointed with their range and prices on car rubber stuff... :?
 Post subject: flares
PostPosted: Mon Sep 18, 2006 6:07 pm
yesss.............. that P shaped rubber sounds good,I could also run it around the door hinges and the seams :o . while I am there I can have a geez at some potential boot and door seals. I was thinking of using some captive bolts for the flares (you know what I mean the ones with no bolt or screw head that tighten up from the rear) has anyone used these?
Cheers guys
Oh wats sicka Flex?
blokeinamoke wrote:
PostPosted: Mon Sep 18, 2006 6:13 pm
It's a polyurethane sealant..think selley's..
PostPosted: Mon Sep 18, 2006 7:26 pm
Selleys don't make it. The nearest they have is a product called `All Clear'- it's not polyurethane like Sikaflex, but you can paint it when dry.
Sikaflex 291 is definitely available from Bias Boating Warehouse, probably Whitworths too- or any place that sells automotive painting supplies to the trade.
PostPosted: Tue Sep 19, 2006 10:23 am
Supercrap has it also surprisingly enough, about $16 each from memory.
I'd probably stick with the standard gaskets for the door hinges, there are rubber ones available too.
PostPosted: Tue Sep 19, 2006 12:04 pm
sikaflex is also used to stick together new lotus's and lambo's etc most modern sports cars. they stick the panels together and then heat treat it. ment to be a shitload better then welding etc because it doesnt weaken whatever its sticking together
