It is currently Sat Aug 16, 2025 4:24 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Feb 04, 2007 5:00 pm
Ok, We took out the starter, and jammed the spanner in the flywheel, so it wouldn't spin when we were taking off the crank & camshaft nuts. The instructions say to align the dots on the timing chain gears. I went to remove the spanner from the flywheel and, of course, it fell in. Does anyone know how I get it out? :cry: :oops: :?
It won't come out with the magnetic pen, infact.. I can't even see it.
Manda.
PostPosted: Sun Feb 04, 2007 5:43 pm
You will probably need to remove the clutch cover, clutch and flywheel.
This can be done in the car in a couple of hours, it's not a big deal. :wink:
Use a main bearing shell instead of a spanner, it fits nice in the ring gear teeth, locks it safely and is probably too big to fall in there.
PostPosted: Sun Feb 04, 2007 7:19 pm
Thanks for the advice everyone! We've decided to do as the doctor says, and finish one end before moving onto the other.
We have taken off the old timing chain and gears ( hooray :P ), and now we need to countersink the bolts. There are 3 bolts sorrounding the camshaft, 2 underneath the crank, so I'm assuming the 2 underneath the crank are the ones that need to be countersunk. I need to take off all 5 to get off the plate? Also, does the plate need a gasket or just sealant?
Here's a pic to describe it...
Also, I read in some other posts about hammering a spot in the timing chain cover in order to accomodate the duplex chain & gears. Here's a pic of ours, does it need hammering, and if so, where? :o
Thanks once again
We love ausmini! :wink:
Marty & Manda
PostPosted: Sun Feb 04, 2007 7:34 pm
Yep- those two bottom ones under and near the crank need countersinking and replaced with counter sunk 'V' head allen screws. Didn't two come with the duplex kit?
PostPosted: Sun Feb 04, 2007 7:37 pm
Gaskets usually OK, but sealant can't hurt. Not too much.
PostPosted: Sun Feb 04, 2007 8:30 pm
That design of cover should be fine, no 'Knocking' required!! This is only required on later covers with the different shape when a tensioner for the simplex chain / and breather is present.
Watch those tiny 3/8 A/F bolts when you refit, easy to strip! also check washers, some bolts bottom out and strip if the washers are left off!
Nice clea n job BTW that's the only way to be inside thre motor! 8) 8)
Sir Alec! we are not worthy!
PostPosted: Mon Feb 05, 2007 8:07 am
It's usually a good idea to "centralise" the TC by inserting the pulley B4 you fully tighten all the TC bolts. Aso, a smear of oil on the pulley shaft so the seal does not run dry and burn :idea:
PostPosted: Mon Feb 05, 2007 9:01 am
I don't use locktabs anymore for any part of the car. They are usually made of soft chinese steel and I have first hand experience of locktabs letting go and what dammage it can do.
Loctite is the way to go on everything, flywheel, flywheel housing, crank pulley, everything that requires a loctab, loctite it.
The only exceptions are ball joints, diff and a few other bits, in which case loctite and locktabs :wink:
PostPosted: Mon Feb 05, 2007 9:41 am
Advice noted - can you advise what # Loctite as i get confused with them all :oops:
PostPosted: Mon Feb 05, 2007 9:56 am
theres so many ay
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Feb 05, 2007 10:11 am
270 or 271
It says "High strength threadlocker" on the bottle
PostPosted: Mon Feb 05, 2007 11:58 am
Try eBay for Loctite - I got a 50ml bottle of 272 for some ridiculous price like $8 from a guy selling multiple items. He is a Motor bike parts place in Sydney. Also got a 50ml of the one for bearings from a private seller for about the same price. I now have enough Loctite to last the rest of my days :lol:
PostPosted: Mon Feb 05, 2007 12:04 pm
GR says don't Loctite the mains or rod bolts, just smear them with molygrease and tighten up. No lock tabs.
It's the stretch in the bolts that keeps them tight. :wink:
ARP bolts NEVER have lock tabs.
PostPosted: Mon Feb 05, 2007 3:05 pm
Yes and don't do rods and mains. Read your ARP installation instructions that come with your rodbolts...
PostPosted: Mon Feb 05, 2007 3:20 pm
ARP say to torque it up three times - backing off between each tightening.
Do you torque to the figure on the dry run to check clearances etc or just nip it up and it doesn't count?
Users browsing this forum: No registered users and 327 guests
