It is currently Sat Jul 19, 2025 10:40 am
 Post subject: Re: Int Boot Hinges
PostPosted: Thu Feb 15, 2007 9:14 pm
Convertible Mini wrote:
Try and have a look at Morris 1100 boot hinges, they are internal. But they would take up too much space in the boot if fitted to a Mini. Anything is possible if you put effort into it. Yes minis look neater if they had no Hinges there.
Morris 1100 hinge from the top... or are you also talking about hinging the Mini boot from the top?
PostPosted: Thu Feb 15, 2007 9:23 pm
Doesn't matter where it hinges from, it can still be moved to do the job!
:D
PostPosted: Thu Feb 15, 2007 9:56 pm
I have thought about hinging ti from the side. I think this would be real trick
Mike
If it cant be fixed with a hammer it cant be FIXED!!
PostPosted: Thu Feb 15, 2007 10:00 pm
But then you would need 1 metre to open it!
The way I'd like to do it is to have the door slide out and up,
like the doors on bus storage compartments.
:D
PostPosted: Thu Feb 15, 2007 10:09 pm
to do that you would need something like the gear out of retractable roofs or something... I have seen it done but I cant think where... I know those mini truck mags like street trucking and trucking street low and low rider mags have this kinds stuf but generally you can buy kits to do it... More often then not though you need to modify it to work and fit..
Ii know this as I have done a lambo door kit on a C5 corvette.. The kit was made for a corvette butt mate it fitted like Crap.. Took many many many hours to get it to work. I will think of a way to get it to work though
Ill get back to you.
Mike
PostPosted: Thu Feb 15, 2007 10:20 pm
My way doesn't involve tracks, it goes up and down in one sweeping motion.
The hinge arms would just be longer, and have a hinge point at both ends.
Realistically I wouldn't do it (not on my current acr anyway) since the boot is
rarely opened anyway.
:D
PostPosted: Sat Feb 17, 2007 12:53 pm
i have figured out away to hinge the boot from the inside its very simple but im not going to tell you your just going to have to wait and see. hehe
Cheers Dan
PostPosted: Sat Feb 17, 2007 1:08 pm
Make the rear seat removable (bolt on? Or use latch on?) then crawl in and weld the boot shut. Mount the battery elsewhere (under bonnet or in cabin (if it's a sealed type)). And yeah, lol silly idea, but an idea nonetheless. :lol:
