It is currently Sat Jul 19, 2025 12:19 pm
Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Mon May 28, 2007 12:31 pm
show us the dyno sheet or it never happened :P
PostPosted: Mon May 28, 2007 1:57 pm
Im sure that jai will post something.if it means anything i was there and saw it on the screen. It kind of made my day as just before he ran his car i had my on the rollers and ended up spinning the center main bearing :cry:
PostPosted: Mon May 28, 2007 2:05 pm
Ouch, you didn't mention that bit! I was just about to suggest you start a trend and post your figures here but that would seem a little harsh now :wink:
PostPosted: Mon May 28, 2007 3:34 pm
When i txtd you stu to give you my results i knew something was not right with the engine.It did the same as what happend at taupo pushing oil out the breather pipe but i thought that was because of the hard lh corners and a poorly designed breather pipe and no catch tank.It pushed all the oil onto jai's dyno rollers and lubed them up.Engine run ok after that so nursed it back to feilding but thats when things became really pear shaped :cry:
PostPosted: Mon May 28, 2007 3:48 pm
ausmini mod
ausmini mod
WOW!
ok, so 102 HP from a 1360... anyone going to share ANYTHING more about this achievement?
Im genuinely interested in great figures like these... as are most others.
Cmon, some details!
Pete.
PostPosted: Mon May 28, 2007 3:55 pm
what sort of house power you reckon you would get out of a standard 1100 engine with 244 cam 12g295 head 3.44 diff?????
will appreciate any TRUTHFULL figures
PostPosted: Mon May 28, 2007 5:12 pm
Carter, power figures, meh, a nice road engine.
PostPosted: Mon May 28, 2007 5:15 pm
Couldnt really tell you has there been much work done to the head how well balanced is the engine.I have seen big bore engines with a bit of work done to them perform really bad on a dyno and smaller engines with only a small amount of mods show some bigger engines up :D
PostPosted: Mon May 28, 2007 5:17 pm
Pristic Pm minicranks he may well just tell you
PostPosted: Mon May 28, 2007 5:52 pm
Hey spaceboy show you as soon as i have done another test on another dyno just to confrim findings yes i know its a different day but im not looking at the whole power thing it was alwaysa a forgone conclusion that you couldnt get 100hp form a single carb on a mini.
it was a 1.75 carb running a BDP needle so its not anything massive.1360cc and a whole lot of lovin
Plenty cars there runnign and got pretty accurate figures for a lot of them and comparitive to std production figures at the crank and most of them were modified in someway or another.
good to see most of the motors i had somethign to do with performed at the top end of the scale. just mike the bugger with his 1430 full noise machine getting 92bhp at the wheels was impressive.
waht carbs do group N cars run over there?????? like greg malures car with a 45 side draught on it?????? not a single SU carb.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Mon May 28, 2007 9:08 pm
Hi Jai,
Most Nb cars I've seen run the good old reliable 45DCOE.
Is this 1360 of yours a rorty roady or a full noise racer??:P
PostPosted: Mon May 28, 2007 9:14 pm
12 months ago I had henry on the dyno at autotec(Eyetie tuner in Fyshwick) and my little 998cc ran 51hp at the crank - I still to this day dont even know what that is at the boots. However power is one thing - fun and good driving scenery is another(and most important)issue.
Bragging rights are good - driving the car that has turned your life into a quest is better IMHO :lol:
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Tue May 29, 2007 8:48 am
Jai's engine was built to a road spec and can be driven down the road with ease and the car is roadworthy . I couldnt believe it but like i said i was there along with about 20 other people
PostPosted: Tue May 29, 2007 9:18 am
My 1030cc LS puts out 40.23HP at the wheels but should produce a bit more once the new head is fitted...
PostPosted: Tue May 29, 2007 9:59 am
Not bad smokie
