It is currently Fri Aug 01, 2025 1:37 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 31, 2007 6:50 pm
Thanks Matt, I will check it out and see what suits.
Owner: 77 Clubbie
Motor: 1415cc Madmatt Stroker motor
Bodywork: Work in progress
Interior: OK no mods not even a radio, yet!
Pictures will follow, eventually!
PostPosted: Thu May 31, 2007 8:13 pm
Yes as Matt says 95 pounds plus 15 pounds for postage.
I hade mine ceramic coated.I was advised not to have it chromed.
Do a search about Ceramic Coated Systems,and see what you think.
PostPosted: Fri Jun 01, 2007 12:37 am
Yes, if you get it chromed it is important not to chrome the inside of the manifold, do the outside only. Is that what you mean LS1380?
Matt
PostPosted: Fri Jun 01, 2007 9:16 am
Yes that correct.The grey ceramic coating isnt the best for looks,but it does stay clean.
PostPosted: Wed Jun 20, 2007 2:35 pm
Hmm,
Older topic, but rather than start a new one,,... i'll carry on here.
I have a set of twin 1&1/2 SU's which need a cleanup/rebuild.
My 1275 is currently running a 1 & 3/4 SU, and I was thinking of using the su's, but also considering perhaps changeing to a weber.
the 1275 has a slight cam, and rest is pretty normal. Also has a sorts system & extractors.
Any suggestions??
74 Mini Leyland - 1275
PostPosted: Wed Jun 20, 2007 8:39 pm
I was wondering what needles you guys are running in your twin 1.5 Sus
I have a 1360, RE13 (from GR) big valve head, exstractors
Thanks
Kiwiinwgtn
PostPosted: Wed Jun 20, 2007 8:51 pm
Thanks
Kiwiinwgtn
I would start with CP4s.
I had these in Barney (1293A+ with Tighe 104 cam, Corolla rockers, rimflow valves, twin HS4s, Perry 3-1 freeflow). But now running #6 (a bit leaner than CP4). A/F trace is now a straight line at 13:1. 8)
PostPosted: Sat Jun 23, 2007 7:41 pm
Thanks Kev
are cp4's fixed or floating needles
Kiwiinwgtn
PostPosted: Sat Jun 23, 2007 8:30 pm
CP4 are fixed needles. They were standard in the Police Pack Mk2 S twin HS4s, which is what I'm running. :wink:
PostPosted: Sat Jun 23, 2007 8:41 pm
my carbs are floating needle , is there a convertor to convert fixed to floating needles
PostPosted: Sat Jun 23, 2007 8:48 pm
If you mean floating to fixed, yes, there is a conversion available to run a fixed needle in a floating setup.
PostPosted: Sat Jun 23, 2007 8:55 pm
I've always preferred fixed needles- if centred properly they don't wear themselves and the jet out. 8)
PostPosted: Sat Jun 23, 2007 9:06 pm
64cooper could i have a copy the coversion chart
PostPosted: Sat Jun 23, 2007 10:01 pm
good to see it running fine. I had twin 13/4 SUs on my 1330 about 20 years ago and she was sweet as.
It really annoys me when people say that this set up is too big. As the good doc, mad matt and others who have used this set up say the engine will use as much air/fuel mixture as it requires by lifting the piston.
Enough said. :)
Oh, for an experiment I whacked them on a 998 with a 1275 head and that ran fine too.
