It is currently Sat Jul 19, 2025 12:33 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jun 19, 2007 10:05 pm
white_mini_man wrote:
A moke, in tassie, nearing winter :shock: , your mad!
NEARING winter. Man it hasn't been above 9 degrees here in over a week! Its gonna be pretty cold when winter does hit!
PostPosted: Tue Jun 19, 2007 10:59 pm
The Forkmeister
Get my vote for Lucas oil sabiliser, I tried that in my clubby and it cured my car of it's smoking habit..... :D
May the fork be with you.
PostPosted: Tue Jun 19, 2007 11:53 pm
Forum Graffiti
Yeah I agree that it doesnt completely stop the smoke but it does help considerably... but man is that stuff thick!! It must've sapped 10 of the 11hp my engine had! :P
PostPosted: Wed Jun 20, 2007 7:36 am
I have been watching the Tassie weather. I was to move to tassie (on the west coast to Rosebery) in July however have now postponed the move to September.
PostPosted: Wed Jun 20, 2007 8:59 am
Nicotine patches work well also :wink:
PostPosted: Wed Jun 20, 2007 10:18 am
Don't postpone on account of the weather, its never any good in Rosebery. Most people don't live in Rosebery anymore, they just stay there during their shift and go back to the north coast in between.
PostPosted: Wed Jun 20, 2007 10:52 am
What is Rosebery that people do shift work ???
A mines area ????
PostPosted: Wed Jun 20, 2007 11:23 am
Used it in the old falcon I had as it was in the boot when I bought it - it increased the smoke(good smoke screen too)
I was warned by a few people down here not to put any additives to mini oil as it doesnt go well with the box. However I do use the Lucas oil stabilizer in the soob and works a treat - the old L-series tappet noise is enough to drive you mad(yes it is worse than a loose timing chain in a mini!!). Sound advice on Doogies behalf and it lasts a while too(I bought the lucas stuff a year ago and still have 3/4 of a bottle left)
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Wed Jun 20, 2007 11:43 am
When I first reco'ed and rebuilt the 1310 motor (with all new parts including a high volume oil pump) the oil used to drain out of the engine and on start up there was no oil pressure (although good once primed and running).
This only happened after a few days of the mini standing I used to have to undo the oil cooler and manually prime the oil pump. Ran fine then.
I put Lucas oil stabiliser in at the recommended level and the pump stopped draining. It hasn't done it since and thats after several oil changes without further Lucas Oil.
I suspect the original problem was ultra clean oil ways and oil pressure producing components, I doubt it was a sticking oil relief valve.
In that respect oil additives definately do work but not as a quasey engine reconditioning agent.
PostPosted: Wed Jun 20, 2007 3:07 pm
I tried some stop smoke in a worn out 998 I had. No difference at all to the smoke! My theory is that if you put thick oil in, it stops smoking briefly but the force of the thick oil makes the rings/guides worse, so that when you put standard 20w50 back in it smokes a lot more. Stupid theory I know, but I'm sticking to it! :lol:
If it is a shot engine and gearbox, sure try it. If you value the gearbox then don't. Chances are it will create drag on the primary gear and you won't be able to select gears easily as has already been mentioned.
I'd be interested in trying that Lucas oil stabiliser, never heard of it but hell I'll try anything once, except line dancing. Not speaking too soon, but the stuff I put in my radiator the other day does seem to have at least improved the crack in my block. I'm not a believer in miracle cures though so I'm skeptical as to whether it will last.
PostPosted: Wed Jun 20, 2007 3:27 pm
Check this site out re a simple test and explanation of oil additives
[/url]
http://www.bobistheoilguy.com/images/lucas/lucas.htm
any thoughts ?
PostPosted: Wed Jun 20, 2007 3:29 pm
Hey there Anto,
Didn't realise you had a cack in your block - bugger hey! Anyhow - see ya tonight at the Mini Meeting. I've got your meat hooks in the car for you! :D
Rob.
PostPosted: Wed Jun 20, 2007 5:12 pm
i put a coulpa bottles in a 78 corrola (3k) that had done 220,000k, without any work, it reduced the smoke a bit, then a rod snapped and a piston shattered (different cylinders), it still ran :lol: but the smoke came out the bonnett vents and the hole in the block, as well as the exhaust :D
PostPosted: Wed Jun 20, 2007 6:22 pm
Location: Woodside, Hahndorf and Mount Barker South Australia
i know that the wynes brand worked in my old kingswood.
