It is currently Mon Jul 28, 2025 4:48 am
PostPosted: Sun Aug 05, 2007 6:02 am
What methods does everyone use to
change the primary gear seal
if you do not have the special seal tool
Thanks Felix
1966 mustang coupe 289 auto
1970 mgb roadster auto
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
http://s160.photobucket.com/albums/t173/1966mini/
PostPosted: Sun Aug 05, 2007 7:19 am
Drive a narrow screwdriver through it and flick it out.
I made a tapered alloy protection sleeve to slide the seal over the splines, although you can wind plastic tape onto the splines and peel it off after seal fitted.
To fit the seal I used a piece of PVC pipe and a BFH. If I did it often in the car, I'd make something better. :lol:
PostPosted: Sun Aug 05, 2007 7:40 am
I normally cut a strip 3" wide and 1/4" bigger than the circumference of the crankshaft from the side of a pet soft drink bottle (pick a smooth sided one , not a coke bottle with it's ridge) , clean up the edges so there's no lip and put it around the inside of the seal , push the sleave and seal over the end of the crank and pull the sleeve out in a turning motion once the seal is in . I used to have a left over scrap of pipe the right size to tap it in but lost that so I use a wide punch and little taps all the way around noe , will have to get another bit of pipe :(
PostPosted: Sun Aug 05, 2007 9:02 am
Thanks for all the info
Felix
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
PostPosted: Sun Aug 05, 2007 4:11 pm
High heel ninja
Thanks Felix
In the time it take to get the clutch housing cover of you can have the engine out, when you have the housing off & the new seal in place, put some tape over the primary gear to protect the seal when the housing goes back on.
Doogie
PostPosted: Sun Aug 05, 2007 6:58 pm
Wrap the primary gear with tape
Use scissors to "modify' a soft drink can, plus some tape to keep it together and put it over the primary gear.
There's my two methods when you don't have the correct tool :wink:
Hooroo
Rod Image
PostPosted: Mon Aug 06, 2007 6:37 am
Thanks again fellow mini members
Felix
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
