It is currently Tue Jul 22, 2025 11:03 am
PostPosted: Mon Oct 15, 2007 1:25 pm
I want to have Al's babies
Done! Thanx for all your help, folks! (especially Ian ;))
PostPosted: Mon Oct 15, 2007 1:35 pm
It only took you one phone call too :P
Satisfying to be able to do something yourself and save a few $$$'s isn't it .
PostPosted: Mon Oct 15, 2007 1:37 pm
Well done Een. Everything is still intact?? :lol:
Talk is Cheap because Supply Exceeds Demand
mattsmadmini wrote:
you've got awesome norbles
PostPosted: Mon Oct 15, 2007 2:08 pm
My trick...
Glue the rocker cover gasket to the rocker cover with Kwik-Grip.
Paint the other side of the gasket with Permatex No3.
No leaks and you can easliy remove the cover to check the rocker clearances.
I know I am a bit late on this one.
I always found it beneficial to silicone the gasket to the head. That way you can remove the cover and the gasket stays in place making refitting easy and stops jagging and breaking the gasket on the rocker arms when removing the cover. It also helps stop any pools of oil from leaking down the the engine when the cover is taken off, acts like a little dam wall. You can reuse the gasket many times.
Pete
PostPosted: Mon Oct 15, 2007 2:59 pm
Yep. Every thing's fine. :D
Ian, it's not so much saving the $, it's the challenge of jumping into to something you know f**k all about. :lol:
PostPosted: Mon Oct 15, 2007 3:02 pm
i hope this isn't too late....
Don't get on the titanic.... i've got a bad feeling about it...
PostPosted: Mon Oct 15, 2007 3:03 pm
Noted. Thanx for the heads-up. *phew*
Users browsing this forum: No registered users and 32 guests
