It is currently Sat Jul 19, 2025 1:22 pm
PostPosted: Fri Dec 31, 2004 7:47 am
didn't he put one in the current one..bugger
PostPosted: Fri Dec 31, 2004 7:57 am
while we are on the subject, Mo has started to spit black (I am guessing) oil from out the muffler. When up against a wall, when you put the foot down and rev him, then move away from the wall, there is this round black splatter from the exhaust.
He doesnt smoke on start up, and leaks about a 20c piece worth of oil per week which seems to come from the gearbox join. Oil is good and pretty clear still having been changed about 4 months ago.
Is this signs of something bad..?? :cry:
PostPosted: Fri Dec 31, 2004 8:08 am
When the motor cools down, you get water condensation in the muffler. When you start it up it comes out the tailpipe, with carbon specks etc. Nothing to worry about. :wink:
PostPosted: Fri Dec 31, 2004 8:10 am
Just park it front of a Bini...and the world will be right again :lol:
 Post subject: Running Rich??
PostPosted: Fri Dec 31, 2004 10:34 am
How long since you changed your air cleaner?? Fiddled with the carby setting lately? The carby might be running rich????
PostPosted: Fri Dec 31, 2004 2:17 pm
:D Champions. After parking in front of a Bini and setting the world right, I took Mo to a mechanic. He said that the carbie is running way rich which would explain the fuel consumption jumping from like 6L / 100km to 8L / 100km..!!!
So... new year he is getting a tune... or possibly the webber put on. :wink:
PostPosted: Fri Dec 31, 2004 6:09 pm
Then with the weber you'll be getting 20L/100km :)
PostPosted: Sat Jan 01, 2005 9:04 am
shhh as long as you dont tell mum..!!!
:lol:
PostPosted: Sat Jan 01, 2005 10:55 pm
OK one more question before bed. I just read in another post place a response to someone getting information about fitting a K&N ram flow air filter which I now have. THey said:
> Also have you considered what needle you may need in the carb once you
> have fitted the K&N? If you fit a K&N, you'll be wanting a richer needle.
Should I have upgraded the needle in my carb once the air filter was changed over? Mo seems to be running rich now, but this person suggested a richer needle. Does this sound right?
PostPosted: Sun Jan 02, 2005 12:20 am
normally when using a sports air filter you are increasing air flow to the engine,
doing this the requires more fuel(richer needle)but in most cases it's a trial and error basis. put the air filter on and tune it with the standard needle, you will soon know if you need to upgrade
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sun Jan 30, 2005 8:26 pm
Sorry Dr... just wanted to check, I have just ran Mo for a bit this afternoon and the junk out the back is increasing. He hasnt been driven for 2 weeks and was in a locked up garage so I would have thought there to be minimal water condensation (dry conditions in the garage).
Still no need to worry..??? :?
PostPosted: Sun Jan 30, 2005 8:50 pm
Depends whether water level in rad is dropping.... :lol: If so it's probably head gasket. :cry:
If not, don't worry, be happy.. :wink:
PostPosted: Sun Jan 30, 2005 9:20 pm
brian mcferrin - dont worry be happy
download it for a laugh :wink:
for u old fogies, it's a song. music n stuff.. ah dont worry :lol:
PostPosted: Sun Jan 30, 2005 10:38 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hmmmm i think that song come out when i was 16 or 17 so over 15 years ago so i think the "older blokes" might actully remember it when it come out not like you has it as a recycled song :)
makka
 Post subject: oil leaks
PostPosted: Mon Jan 31, 2005 7:54 am
Check how old your muffler is and whether its full of gunge, Often if oil is being spat out the breather hole its because the muffler is blocking up. I experienced this problem a few years back. My muffler was full of oil and grunge because of the poor condition of the engine. Its a problem because the oil thats being spat out will coat the radiator and reduce its working surface making everything run way to hot. Take the muffler off and see if its light or feels like several house bricks. Worth a check its cheaper than a new motor.
Steve
