It is currently Mon Jul 28, 2025 2:37 am
PostPosted: Wed Nov 14, 2007 7:16 pm
True
But how did it cause the car to drop a cylinder and consistantly just that cylinder.
BTW - has anyone told Kev07 that we have crap fuel ????
Simon - got an invoice for me yet ???
Mike
This space for rent
skssgn wrote:
niceboy1275 wrote:
Yes I did fill up with V power.. why? :shock:
cos it's rubbish fuel
The general consensus around here is that V-Power (ex Optimax) is not good in a Mini engine, lotsa people have had problems with it fouling the plugs. BP Ultimate 98-octane is generally agreed to be the best fuel, if you can get it.
PostPosted: Wed Nov 14, 2007 7:17 pm
This space for rent
Mike_Byron wrote:
True
Exactly, which is why I don't think this is the primary cause.. it may be a contributing factor, but it's not likely to cause the engine to drop one cylinder all by itself.
PostPosted: Wed Nov 14, 2007 7:24 pm
Mike_Byron wrote:
True
Mike
yeah, regardless of the fuel, I'm with Morrie... something got wet... or it's done a head gasket
and no Mike, no invoice - I haven't been asked to pay by the account owner yet.... do we have any fowl emergences yet?
PostPosted: Wed Nov 14, 2007 7:37 pm
Yep - far too many silkies that are not going to come up to show standard - the greater majority are going to clearing sale on sunday unless specific requests come in ????? Want some ?????
Sorry mini-ists but this is important stuff :oops:
Mike
PostPosted: Wed Nov 14, 2007 8:12 pm
well i've just changed the plugs, points, condesor, rotor button, dizzy cap and leads all with brand new items, and still no change. When I have some more cash, i'll run it out to the mechanics to check the head gasket. Failing that, it will probably be up for sale on here. I can't afford to keep a car that requires rebuilds every 4000kms. Rant over.
On a positive note, thanks to everyone for their advice and help. Greatly appreciated guys!
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Wed Nov 14, 2007 8:21 pm
This space for rent
If you don't already have one, go to Supercrap and buy a cheap compression tester, then check the compression in the suspect cylinder vs the others.
That'll give you an idea whether it's fuel/ignition, or something more serious like a gasket, valve or rings.
PostPosted: Wed Nov 14, 2007 9:53 pm
I use a very cheap compression tester, it's called a thumb. `Individually' calibrated. 8)
Works for me, is fully portable, good enough to check for a dud gasket. :wink:
PostPosted: Wed Nov 14, 2007 9:58 pm
Why did you change the plugs, points, condensor, rotor button, dizzy cap and leads?
Why didn't you change the wiper blades as well? 8)
You have to find what is wrong before going to the parts store.
PostPosted: Thu Nov 15, 2007 7:56 am
I didn't go to the parts store. Im a mini owner. Therefore don't we all just naturally keep one of everything in stock? I do.... :) Everything else on the car is new, so I figured because they were the only things not replaced when the engine was last rebuilt, I may as well change them now.
PostPosted: Thu Nov 15, 2007 8:29 am
I've seen the fleet - Niceboy1275 your not a mini owner - you're THE mini owner :wink:
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Fri Nov 16, 2007 2:23 pm
Well today, up bright and early, went and hired a car carrier, loaded the mini onto it, drove out to the mechanics, unloaded it, he started it up, and said "I bet your piston in the carby is stuck" 2 screws, a tap of the hammer, and 5 minutes later, shes purring like a kitten. So drove it home and she didn't miss a beat.
Wanna say thanks to everyone out there who gave me their piece of advice, was definetly welcomed and gave me a bit of insight as to what to look at next time. THanks a lot guys.
:D
PostPosted: Fri Nov 16, 2007 2:40 pm
:D
Ah, good one :)
I think everybody ran with your assumption that you had dropped a specific cylinder, rather than just getting performance eqivalent to such. Nevermind, at least we know what to look for when we actually do drop a pot :)
Glad you got it sorted!
Gareth.
PostPosted: Fri Nov 16, 2007 3:35 pm
[quote="Smegger"][quote="niceboy1275"]Well today, up bright and early, went and hired a car carrier, loaded the mini onto it, drove out to the mechanics, unloaded it, he started it up, and said "I bet your piston in the carby is stuck" 2 screws, a tap of the hammer, and 5 minutes later, shes purring like a kitten. So drove it home and she didn't miss a beat.
:D[/quote]
Ah, good one :)
I think everybody ran with your assumption that you had dropped a specific cylinder, rather than just getting performance eqivalent to such. Nevermind, at least we know what to look for when we actually [b]do[/b] drop a pot :)
Glad you got it sorted![/quote]
Too true! Thanks for your input buddy
PostPosted: Fri Nov 16, 2007 4:21 pm
niceboy1275 wrote:
:D
Ah, good one :)
Great news Jay - :wink:
'71 Wolseley 1300
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
