It is currently Tue Jul 22, 2025 8:11 pm
PostPosted: Thu Nov 15, 2007 9:47 pm
lol if you have to take the exaust and inlet manifolds off and then your nice buff arms should have no trouble
Mearcat wrote:
PostPosted: Thu Nov 15, 2007 10:03 pm
yeh, but i think in order to preserve all the intense ponds institute treatment that my massively buff arms of received, i'll get the wife or son to tackle it.
PostPosted: Fri Nov 16, 2007 12:48 am
lols
Mearcat wrote:
PostPosted: Fri Nov 16, 2007 8:23 am
If you have any friends with 4 elbows they might be able to help you out :?
Failing that, I would try finding a kid (or your son) to help you out.
PostPosted: Fri Nov 16, 2007 8:30 am
the tasmanians should be alright with it..
PostPosted: Fri Nov 16, 2007 9:11 am
Well, a very short drive and the speedo still isn't working and I don't know why???
Every thing seems to connected ok at both ends.
Might pull the new inner cable out and measure it against the old cable and see if it's the right length..
Update: The new inner cable is 45mm longer than the old one. Would it being longer make a difference to why the speedo wont work??
Update on the update: Size does not matter in this case. I have finally got the speedo to work.
I put the car up on stands, pulled the cable out of the speedo behind the dash, started the car and put it in gear while watching the inner cable. At first the cable didn't spin but I gave it an extra hard push further into the outer cable and away it went.
Put it all back together, one more run on the stands and all is good.. :D
PostPosted: Fri Nov 16, 2007 12:14 pm
I did mine from underneath - car on a hoist.
But I guess that cheating...
PostPosted: Fri Nov 16, 2007 2:46 pm
How dare you do it the easy way Mort Subite... :shock:
