It is currently Mon Jul 28, 2025 3:10 am
Post new topic Reply to topic  [ 110 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
PostPosted: Thu May 08, 2008 10:53 am
Surely you could set up a video camera so that we could sit and watch 24 hours a day. It would be enthralling to watch as once every hour a little bubble might hit the surface and burst its way to freedom. Keep up the good work!
PostPosted: Thu May 08, 2008 12:07 pm
Milatsmadmini
so..... whats the results morris? :lol: i cant believe im actually excited to see the outcome :shock:
PostPosted: Thu May 08, 2008 6:59 pm
Well after 1 day there is not much to see. The vinegar is bubbling away and slowly changing from brown vinegar to rust coloured vinegar.
It does not look like there has been much of a difference but all the loose stuff has gone and it is starting to eat into the rust.
So we will see how it looks tomorrow.
AEG163job wrote:
OK Morris let me guess - you're looking for the cheapest rust removal product on the market ? :lol: :lol: :lol:
I am not looking for the cheapest rust removal product, I am just showing an easy way to clean rust of metal and to loosen rusted bolts. ( I am a tightarse but that is not the reason for the experiment!)
1310/71 wrote:
why not run a parallel experiment on molasses?
KB
I will clean up the other half of the clamp with molasses, that is going to be the part 2 of this experiment. (there may be a part 3)
PostPosted: Thu May 08, 2008 7:21 pm
Try salt water for the part 3, I want to know what happens :lol:
PostPosted: Thu May 08, 2008 7:23 pm
If you want it to rust quickly you just take it out of the vinegar and leave it an hour. :shock: It changes colour while you watch.
PostPosted: Thu May 08, 2008 7:28 pm
Try this will work on the that rusty clamp and will release the bolt
This works, i use it alot and its cheap cheap
http://www.stovebolt.com/techtips/rust/electrolysis.pdf
Have just done a very rusty fence strainer worked a treat
Kiwiinwgtn
PostPosted: Thu May 08, 2008 8:18 pm
Slow-Po
How about giving Coca-cola a go?
PostPosted: Thu May 08, 2008 8:19 pm
:twisted: you could have done all three at the same time :roll:
cant say I have anything around the same rust to try some thing also
Let us know when you can get the bolt out :wink:
PostPosted: Thu May 08, 2008 8:21 pm
I don't have that many exhaust clamps. :mrgreen:
PostPosted: Thu May 08, 2008 9:14 pm
To be honest, why? I bought this stuff called EvapoRust, although there may be similar products in Aus. It's about NZ$50 for five litres, environmentally friendly, more or less odourless and reusable. You soak the part for 24 hours, the rust is gone and the part is protected against rust for weeks.
I mean, unless you get a load of vinegar for free, I can't see it being effective or cost-effective. Although I should add, interesting to see the effect of vinegar or coke - kind of like a low budget mythbusters episode :)
I'll do a test tomorrow if I can, and post the results.
PostPosted: Thu May 08, 2008 9:37 pm
i did that....worked well for me
finally own one :D
PostPosted: Thu May 08, 2008 9:39 pm
Coke would work because it's got phosphoric acid in it = that is what is in all the 'Rust Converters' on the market. I always look for the cheapest with the highest concentration of H2PO4 Coke would not be that cheap and you can't drink it afterward :cry:
PostPosted: Thu May 08, 2008 10:49 pm
but it gives me the excuse to buy a 24can pack, use 3 cans for the mini, and the rest to drink YAY
finally own one :D
PostPosted: Thu May 08, 2008 11:21 pm
Morris, not too late to sneak the vinegar back in mum's pantry. Quit while your'e in front, old son.
Vinegar (acetic acid) is a very weak acid. Only 1-5% ionization compared to in-organic acids (hydrochloric, sulphuric) which are 100% ionized. But these attack the metal, not just the rust, as we know, so something less potent needed.
PostPosted: Thu May 08, 2008 11:50 pm
[img][img]http://i187.photobucket.com/albums/x4/olsenp/alien.jpg[/img][/img]
Full of "molecular acid" :lol:
Cut one up :) Pretty powerful stuff (in the movie).
