It is currently Sat Jul 19, 2025 11:54 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Thu Feb 05, 2009 9:51 pm
DOES THAT MEAN : u didnt pass the blue slip ??? :?
PostPosted: Thu Feb 05, 2009 9:57 pm
Tomboss Breweros
Try this to test the distributor side of the circuit.
Ignition off for entire test.
Disconnect all wires from - side of coil.
Connect your test light clip to the main power lead on the start solenoid, now the test light will light up when the probe is put to ground.
Put the test light probe to the wire from the distributor.
With the points closed it should light, open and it should be out.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Feb 05, 2009 10:18 pm
Good tip.
PostPosted: Thu Feb 05, 2009 10:39 pm
Tomboss Breweros
Hanra wrote:
Good tip.
I'm flattered, thankyou. :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Feb 06, 2009 9:45 am
when i pull - wire off coil and put circuit tester clamp on power, pointy end on wire to dizzy open and close the points the light just stays on it doesnt go out......tried other coils that are on other cars and they have the same problem on my car so cant be my coil.>????????????????????????????????????
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Fri Feb 06, 2009 10:05 am
Tomboss Breweros
Yep, coil probably ok.
Check where the wire going into the dizzy isnt rubbed through.
Check where the wire bolts to the pin on the points, it must be insulated from the pin, only contacting the points spring.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Feb 06, 2009 10:09 am
Sounds like you have a Number 5 is Alive Movie then!!!
PostPosted: Fri Feb 06, 2009 12:43 pm
Tomboss Breweros
Be careful of sparks when the ignition is on :shock:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Feb 06, 2009 1:03 pm
Location: NSW South Coast east of Nowra (NOT East Nowra)
"Number 5 is alive" refered to 8 times not counting Short Circut references pretty good.Someone needs to change their Avatar me thinks :lol:
PostPosted: Sat Feb 07, 2009 1:31 pm
problem all solved was shortin out in dizzy. thanks for ya help.
1970 mini k
1975 leyland
PostPosted: Sat Feb 07, 2009 1:33 pm
There ya go, now you know what a Short Circuit is. Glad its all sorted for you.
Number 5 is alive!!!!
PostPosted: Sat Feb 07, 2009 2:26 pm
More input
PostPosted: Sat Feb 07, 2009 4:51 pm
So it was the correctly adjusted points that were the problem. :lol:
PostPosted: Sat Feb 07, 2009 6:13 pm
carter wrote:
no short circuit that i know of
It was just the short circuit that he didnt know of.
