It is currently Fri Jul 18, 2025 10:44 pm
PostPosted: Sat Feb 07, 2009 7:53 pm
:D
How about bore posting (sp) like the civic guys do, they screw a stud into the block to support the bore?
blokeinamoke wrote:
PostPosted: Sat Feb 07, 2009 9:45 pm
The idea I had was to take a cut off the top of the block around bores and remove the cylinders down to the bottom of water jacket. Then off set bore the base and machine up some barrels off a VW and set them up as wet liners.
Then fit new top plate with "O" ring seals basically like a wet liner diesel eng.
I worked out that the bores could go out to to 78mm .
A lot of stuffing around to achieve little. That project was dumped in a corner.
www.minisprintgt.com
PostPosted: Sat Feb 07, 2009 11:58 pm
mind you you would have a fairly high capacity.
1600cc
I have a mill on its way, if its possible I will look into it.
My time is worth very little :D
