It is currently Tue Jul 22, 2025 5:11 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu May 07, 2009 8:39 am
love my polished Alloy but I think making them out of steel will be easier :wink:
PostPosted: Thu May 07, 2009 9:00 am
Well once I've got the design right alloy will be easy, as I know a bloke thats got a water jet cutter. But, that also costs money, so I'm not apposed to doing it all myself with whatever scrap I've got lying around :lol:
PostPosted: Thu May 07, 2009 9:02 am
you should sell them if u get the design right :)
i would buy a set hahah
and go body colour steel ;)
PostPosted: Thu May 07, 2009 12:19 pm
For anyone else interested, here's a pic of a working design:
PostPosted: Thu May 07, 2009 12:21 pm
nice what thickness steel did you use for the main part of the hinge?
PostPosted: Thu May 07, 2009 12:35 pm
Saw this car in Enzud recently.
No external hinges and no handle. It had 2 security keyholes and that was it!
PostPosted: Thu May 07, 2009 12:38 pm
all that needs is pop entry doors with no handles.
PostPosted: Thu May 07, 2009 12:39 pm
Sorry, there not mine. "camp_fredd", The Rat on TMF
PostPosted: Thu May 07, 2009 12:48 pm
The bracket the bolts the hinge to the floor. Is it possible the it provide the 'stop' for the hinge rather that the hinge hitting the body work (and eventually bending it).
ozmotorsport, ain't seen that name 'round these parts for a while.
PostPosted: Thu May 07, 2009 12:55 pm
JC, yeh, you can add a stop to it, or the better option imho would be a strut to limit the opening (like the factory chain/wire)
PostPosted: Thu May 07, 2009 1:16 pm
I know it wouldn't necessarily be practical and the mechanism would take up loads of space, but i always thought it would be cool if you could build a drawer unit.
Just click the handle and the whole thing slides right out...
PostPosted: Mon May 11, 2009 9:35 pm
Not perfect, but cleaned up a bit more and once the rest is all finished will be fine.
PostPosted: Mon May 11, 2009 9:39 pm
nice work mate
were did u get that thick steel from and wat u use to cut it?
great stuff, if your going for the smooth and de bumperised look you should de seam it too (if you havent already) and shave the boot and just have an electric boot opening.
should end up looking tops
PostPosted: Mon May 11, 2009 9:49 pm
I've de-bumpered, but I'm not deseaming. And I will be shaving the bootlid handle as well.
The hinges are doubled up 3mm alloy plate, and the mounts on the bootlid are 1.6 or 2mm steel angle (from the disposable gas bottle mounts from my welder :D) and the boot floor mounts are 3 or 4mm thick angle steel.
