It is currently Wed Jul 23, 2025 7:51 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 28, 2009 11:02 am
If it's a wrrrrring noise rather than a high pitched squeek as you describe it then it's probably a wheel bearing. Don't worry too much, they take ages and ages to sieze... (at least a few hundred miles). Replace both sides
If it's a high pitched squeek then it may be something else?
PostPosted: Thu May 28, 2009 11:21 am
Check - that your subframe tower bolts are tight.
PostPosted: Fri May 29, 2009 3:55 pm
does it get louder when you load a certain side up
nope. no sound when turning, only when straight
i puled split pin out of wheel bearing did it up a bit tighter put pin back in and it went away
will have a look, but no point if i'm going to do the bearings anyway?
err... it's kind of a high-pitched, squeaky whirr... i've left the car in the middle of the garage so i can go and test it. should get around to that while it is still daylight... :lol:
the steering doesnt feel any different, if a bearing was on it's way out i would get shaky steering wheel?
i don't want to be out somewhere or on my way to work when it seizes...
will do!
78 Leyland Mini - Prince
PostPosted: Fri May 29, 2009 5:24 pm
You might not have enough / any grease left in the bearing. Rather than it starting to fail it might just be squealling a bit due to metal to metal contact.
Pull the bearing out and replace, or if you want to take a short cut :? just clean it up and repack it with grease. Might get you another few months if there's not to much damage already. :wink:
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Fri May 29, 2009 5:30 pm
if it's the bearings, i might as well just replace them. not much point getting in there and getting filthy if i'm just going to have to do it again in a few months... i'll just have to wait till next week to get the bearings (can get one now and one next week but might as well save the cash this week, no point buying one at a time)
and then get bearings for the rear in another couple of weeks...
PostPosted: Fri May 29, 2009 8:26 pm
Dylan, hows your brake pedal? Have you had your brakes adjusted recently?
Has part of the car possibly fallen in the the path of your tyres and only rubs when it in a straight ahead position :P
Have you jacked the car up and given the wheel a wiggle up and down to check for excessive movement from the bearing or the c/v nut??
:P The squeak could be the person that you were going to give a ride home from the pub last weekend but forgot you put them in the boot.
PostPosted: Fri May 29, 2009 9:36 pm
Did you say the squeaking stops when the wheels are turning?
Whats the problem then? :?
PostPosted: Fri May 29, 2009 10:26 pm
the straight bits between the corners! by they way, i think i live about 15 minutes from you, in clifton springs...
scott, i adjusted the brakes before the lorne cruise, but they are due for another hit. however, it is definately possible, nay, probable that my car is falling apart :lol:
the wheel wiggle is the test i meant to do. but didn't...
and besides, i most certainly DID NOT drive to the pub last week. i know this because i spent almost 50 bucks on the taxi home :shock: :evil:
PostPosted: Sat May 30, 2009 12:23 pm
no EXCESSIVE movement where there shouldn't be...
PostPosted: Sat May 30, 2009 1:17 pm
:idea: does the noise speed up and slow down with veehicle speed :?:
:? does the noise make a constant sound especially when going over bumps in the road :?:
:) does the noise go away on all types of left and right turns or only one way :?:
:shock: how much for your children :?: :lol:
PostPosted: Sat May 30, 2009 5:27 pm
If you have trouble hearing the noise to decide wether it is a wheel bearing or not, a good trick is to find a hill, roll down it in nuetral with the engine off. Thats a good way to narrow down what the noise might be.
Users browsing this forum: No registered users and 129 guests
