It is currently Sun Aug 10, 2025 2:30 am
PostPosted: Fri Jun 12, 2009 5:47 pm
I think any one who ownes or owned a mini has had brake problems, i know i did :)
PostPosted: Sat Jun 13, 2009 5:38 pm
WTF is going on :evil: I fitted the new brake cyl, bled the rear system and they were all good. Go out for a drive and they stop working again the same way, pedal kept getting lower and lower until I had no brakes. So today I checked the rear cylinders again and they seem fine, theirs no fluid in the rubber seals and I can't see any coming out anywhere :roll: looked over the disc's and couldn't see anything their either.
If I pump the pedal up fast I get some feel but as soon as I let the pedal up and push down again it goes straight to the floor :x
Any one got any more ideas :?:
PostPosted: Sat Jun 13, 2009 5:42 pm
youve got air coming in fromt somewhere or your master cylinder is rooted
Potato
PostPosted: Sat Jun 13, 2009 5:57 pm
Meenie is right, Are you sure you bled them right?
PostPosted: Sun Jun 14, 2009 2:37 pm
Ok we bled them again and the pedal came good but we couldn't get much or any fluid out of the drivers rear cyl.
(1) Is this bias necessary or can a simple T piece be fitted?
(2) http://www.minisport.com.au/prod616.htm After reading the description do I need a new one?
PostPosted: Sun Jun 14, 2009 4:02 pm
The tiny little bleed hole in the rear cylinders can fill with crud.
Take the nipple out and stick a bit of wire in there, or a tiny twist drill.
If still no fluid, your rear hose is swollen shut. Fit 2 new ones. :wink:
Yes that limiting valve is essential, if you bin it the rear brakes will lock up.
PostPosted: Sun Jun 14, 2009 8:02 pm
It's a brand new cylinder But I will have a look at the nipple.
All the hoses, metal and rubber are brand new (6 months or so).
The valve was an old one I had lying around, when I put it on I didn't clean it or rebuild it but it has been working fine until now which is why I think it may be faulty. What we can't understand is theirs no fluid coming out but the brake still works on that wheel :roll: :? .
PostPosted: Sun Jun 14, 2009 8:54 pm
Somebody on either this forum or MM one said they had bought a new rear wheel cylinder, and found the bleed hole wasn't drilled!!
Don't press hard on the brakes when bleeding the rears, or that valve will lock the fluid flow off.
:lol:
PostPosted: Sun Jun 14, 2009 10:02 pm
:lol:
Thats what i've been told, that when bleeding the back only use light pressure on the pedal, otherwise the valve locks and you only get a tiny amount of fluid out.
Users browsing this forum: Bing [Bot] and 86 guests
