It is currently Wed Jul 23, 2025 11:29 am
PostPosted: Fri Jun 26, 2009 10:18 pm
Unleaded seats are fine, if fitted properly (shrink fit). Look at alloy heads, they all have them.
However, many shops doing A series heads just press them in. One UK mag showed how to `fit' them with some elbow greases and a VBFH!. :shock:
Have a bit of an overheating episode, and they can come out. Not a pretty sight when this happens.
PostPosted: Fri Jun 26, 2009 10:36 pm
The Coefficient of expansion for Aluminium is far greater than that of Cast Iron, Therefore it requires far closer tolerances to get a reliable shrink fit in cast iron than aluminium.
Far closer than most of the two bob machine shops that are around these days are capable of anyway!
Dave
PostPosted: Fri Jun 26, 2009 11:17 pm
Everybody else can keep their unleaded conversions, I,m quite happy with my little bottle of lead additive. :)
PostPosted: Fri Jun 26, 2009 11:33 pm
Longmam GT6 must be a rare and sort after model for that kinda money. All I see is a mildly worked 1275 head. Correct me if I am wrong?
blokeinamoke wrote:
PostPosted: Sat Jun 27, 2009 12:21 am
High heel ninja
74snail wrote:
Its a damn shame they ruined it by making it unleaded, nobody in there right mind converts their head to unleaded, just use Flashlube or whatever brand and everything lives longer and so does your money.
What a dopey comment!!!!!
So do you light having to remember to stuff around putting flashlube in everytime you fill up? What a pain in the arse!
Enjoy stuffing around.
Doogie
PostPosted: Sat Jun 27, 2009 10:29 am
This space for rent
I do, it's no big deal... :roll:
PostPosted: Sat Jun 27, 2009 11:01 am
me too, its no dramas for me!
-Cam :lol:
PostPosted: Sat Jun 27, 2009 6:26 pm
I don't add anything. Who cares.
PostPosted: Sat Jun 27, 2009 8:56 pm
i have heads here that havn`t used flashlube "Ever" & there`s absolutely nothing wrong with them after 9 years of use,,, & NO they`re not fitted with inserts
PostPosted: Sat Jun 27, 2009 10:42 pm
TheMiniMan wrote:
David (sitnlow) is dead right,,, sharp pointy edge in the dived between the ports is just crap,,, "POOR" very "POOR"
& i have heads here that havn`t used flashlube "Ever" & there`s absolutely nothing wrong with them after 9 years of use,,, & NO they`re not fitted with inserts
My son ran a fresh recoed 202 head on his 1098 Mini for 6 months to see what would happen, and the ex valves pulled bits of cast iron out of the seats.
I still have the head here.
With Flashlube my 1360's valves and seats stay shiny, last time off I just wire brushed them. They stay far cleaner than they ever did with leaded fuel. :wink:
PostPosted: Sat Jun 27, 2009 10:45 pm
Well that was your fault for recoing the head. If you had left it alone it would have been Ok. :lol: :lol: :lol:
PostPosted: Sat Jun 27, 2009 11:20 pm
My 26.9cc 12G295 with 1100 Rimflow Valves will only be on Lead Additive, it was suggested to me to convert it to lead-free but I had heard the stories of the inserts breaking and thought I,m not risking a $1400 head. It doesnt look as good as it did when I got it back from Hoppers Heads, it's been patiently waiting on the shelf.
[img][img]http://img507.imageshack.us/img507/7963/12g2951100rimflovalves.jpg[/img][/img]
PostPosted: Sat Jun 27, 2009 11:43 pm
ginger ninja
ginger ninja
I am getting a motor rebuilt shortly and a bit of head work done and I am not getting unleaded seats. I do not see a problem with using flash lube and I do not have the spare few hundred there to spend to convert.
sports850 wrote:
PostPosted: Sun Jun 28, 2009 12:15 am
NEWSFLASH: I don't run flash lube or have unleaded valve seats. GR's own recommendation. There's more to it than meets the eye... 1275's don't have as much of a problem as small bore heads do, has something to do with the way the head is ported in the exhaust valve.
In any event I will let you know how it's doing when I next pull the head off but I suspect it's fine...
PostPosted: Sun Jun 28, 2009 10:39 am
sitnlo62 wrote:
I don't like that sharp divider between the two intakes.That shape is so old school.
That section should be rounded for best flow!
Dave
Dave,,, that`s the center exhaust port, :-)
Users browsing this forum: kirby and 93 guests
