sgc wrote:
NG wrote:
i think ill bite the bullet and get it.
i will wait a bit firstly.
thanks for your help
No worries
Seriously, do consider a Pulsar dizzy or (if your dizzy is in OK condition) an electronic module, those options are much, much cheaper and will get you within a few HP of maximum with all the other benefits of the 123. I like the 123 for its tweakability, I'm a fiddler
Next on my agenda is a Megajolt / EDIS setup so I can set the advance from my laptop
If fitting a Pulsar dizzy don't just bolt it in there.. the advance curve is wrong. If timed right at max advance it will have too little advance down low. If timed to normal static timing it'll have too much max advance.
Send it to Graham Russell with your engine specs, and he can change the curve at minimum cost. Nothing like $180.
It made an enormous difference to my well modified 1360.
