It is currently Tue Aug 05, 2025 9:47 pm
PostPosted: Sat Oct 10, 2009 9:55 pm
sgc wrote:
NG wrote:
i think ill bite the bullet and get it.
i will wait a bit firstly.
thanks for your help :)
No worries :) Seriously, do consider a Pulsar dizzy or (if your dizzy is in OK condition) an electronic module, those options are much, much cheaper and will get you within a few HP of maximum with all the other benefits of the 123. I like the 123 for its tweakability, I'm a fiddler :lol:
Next on my agenda is a Megajolt / EDIS setup so I can set the advance from my laptop :lol:
If fitting a Pulsar dizzy don't just bolt it in there.. the advance curve is wrong. If timed right at max advance it will have too little advance down low. If timed to normal static timing it'll have too much max advance.
Send it to Graham Russell with your engine specs, and he can change the curve at minimum cost. Nothing like $180.:shock:
It made an enormous difference to my well modified 1360.
i don't have a Pulsar dizzy i have a 94 A+ one..
so do i chase up a already converted pulsar one or use what i have?
then send to GR
PostPosted: Sat Oct 10, 2009 10:12 pm
I would use the one you have, send it to GR, he has a dizzy machine.
But PM him first to check.
PostPosted: Sat Oct 10, 2009 10:17 pm
ok done..
yes i have been told it makes a massive difference.. i just want to make sure it has the torque down low..
but still easy to drive.
PostPosted: Sat Oct 10, 2009 10:32 pm
This space for rent
Important thing to remember is that a dizzy won't get you any additional horsepower. It will however allow your engine to make all the horsepower it's capable of. If curved badly it will cost you power.
If your engine is capable of torque down low and the cam makes it easy to drive, then all a good dizzy will do is let the engine produce those results.
The really massive difference an electronic dizzy with the right curve will make over a mechanical one in good condition with the right curve is the maintenance -- you'll find the leccy one will stay in tune much, much longer.
PostPosted: Sat Oct 10, 2009 10:37 pm
yes totally clear.. thanks so much for your help lads.. this is kinda what i have below. i do not know what cam that is he said it is good for what i want.
1275 bored to 1293 A+ block
pistons decked 10 though or something to fit flush with block. raised comp Ratio?
Twin 1 1/4" SU carbs
Head ported & polished seems to have had a but of work but i don't know what. the Engine guy when he looked at it quote*** OOO! POCKET ROCKET* had double valve spring in it allready.
25/65 freshly ground 1275
double valve springs
double Row chain
standard A+ rods
standard A+ crank +.010” all over i think
Mini LCB extractors
RC40 exhaust
maybe 80hp ?
Users browsing this forum: Bing [Bot], i got a mini and 101 guests
