OK may be acused of being a noob...
There were 2 metro callipers, A type and B type. B types are no longer available but had only 2 bleed nipples, so if you have these they ain't much use because it is very hard to get the pads and impossible to get pistons etc.
The A type had 3 bleed nipples and were made for both the vented and non vented discs. The difference is that the vented callipers had the spacer! However there are some A type callipers for vented discs without spacers, I know because I have a pair...
Another thought for you why not use the duel circuit callipers as rover intended. Makes it safer which is what Rover were doing when they made the Metro calliper....
http://i962.photobucket.com/albums/ae101/troggle/th_TwinCircuitCallipers.jpg
