It is currently Mon Jul 28, 2025 10:05 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Thu Nov 26, 2009 5:00 pm
P.S
Have fun drilling holes...
was told just too be carefull not to get too much drill fibers inside the caliper..
i have no idear how to do this....maybe blow compressed air threw them once done...??
PostPosted: Thu Nov 26, 2009 5:26 pm
Maybe cover the drill bit in grease?
PostPosted: Thu Nov 26, 2009 5:29 pm
If you drill it with the caliper pistons out then you can get all the swarf out.
PostPosted: Thu Nov 26, 2009 5:31 pm
And you can fit new caliper seals while it is apart. :wink:
PostPosted: Thu Nov 26, 2009 6:08 pm
swarf ?? is that the name for a female smurf...hahaha
sorry bad humur...
PostPosted: Thu Nov 26, 2009 7:12 pm
OK may be acused of being a noob...
There were 2 metro callipers, A type and B type. B types are no longer available but had only 2 bleed nipples, so if you have these they ain't much use because it is very hard to get the pads and impossible to get pistons etc.
The A type had 3 bleed nipples and were made for both the vented and non vented discs. The difference is that the vented callipers had the spacer! However there are some A type callipers for vented discs without spacers, I know because I have a pair...
Another thought for you why not use the duel circuit callipers as rover intended. Makes it safer which is what Rover were doing when they made the Metro calliper....
http://i962.photobucket.com/albums/ae101/troggle/th_TwinCircuitCallipers.jpg
PostPosted: Fri Nov 27, 2009 6:50 am
well the swarf will come out as i have already got the pistons out and acquired new seals...
the only problem now is ensuring the hole is drilled at the right angle...
Users browsing this forum: Bing [Bot], jimb and 80 guests
