It is currently Sat Aug 09, 2025 7:40 pm
PostPosted: Wed Mar 24, 2010 10:54 am
the piston in the carby is probably stuck
PostPosted: Wed Mar 24, 2010 11:46 am
Got electronic dissy so no points. I can move the piston easily
Potato
PostPosted: Wed Mar 24, 2010 11:54 am
What's the condition of the plug tips? Might tell if it's running lean or rich. Any smoke of any kind?
Edit: may as well brush and gap the plugs while you're there
Copper 4 lyfe!
PostPosted: Wed Mar 24, 2010 7:12 pm
plugs are brand new and gapped correctly..
i got it going slightly better today.. but runs nice when i put my hand over the back of the carby.. what does this mean? i dont have any air leaks anywhere else that i can find......
Potato
PostPosted: Wed Mar 24, 2010 9:47 pm
What about ignition/dissy timing:?:
Whats the compression like :?:
Have you checked cam timing/position :?:
PostPosted: Wed Mar 24, 2010 10:44 pm
sounds like the carby is just too lean,,, if it`s off a 998 & youre trying to make it run on a 1275???
if thats the case then it`s just too lean,,, & you`ll need a richer mixture needle to suit the bigger engine,,, & Maybe a stronger carby dash-pot spring too
yeah?
PostPosted: Wed Mar 24, 2010 11:04 pm
meeni wrote:
..... but runs nice when i put my hand over the back of the carby.. what does this mean? i dont have any air leaks anywhere else that i can find......
Does it stall when its running & you completely cover the carby intake?
