It is currently Sat Jul 19, 2025 3:02 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
Which paint have you found holds up best??
Supercrap engine paint aerosols 19%  19%  [ 4 ]
repco engine paint aerosols 0%  0%  [ 0 ]
autobarn engine paint aerosols 0%  0%  [ 0 ]
2 pak 24%  24%  [ 5 ]
specialise paint shop aerosols 5%  5%  [ 1 ]
use primer as well as aerosols on engine 19%  19%  [ 4 ]
other 33%  33%  [ 7 ]
Total votes : 21
PostPosted: Mon Jul 25, 2011 11:28 am
seifer wrote:
It was around $50 I think, not cheap but I was happy with the result.
gosh, that's cheap in my opinion. If that did enough for the whole engine? Spray aerosols are now $20 each, and normally i use 2 or 3...
where did you go to get the paint?
PostPosted: Mon Jul 25, 2011 11:45 am
I did my whole engine and still have 3/4 of a tin left so if you look at it that way it is good value.
So... I'm Seifer
PostPosted: Mon Jul 25, 2011 12:23 pm
not sure where to by por15 but found this online..
http://www.ppcco.com.au//cat/index.html
they even do a bmc green, pity it's not the metallic
PostPosted: Mon Jul 25, 2011 1:13 pm
yeah I just order straight from there, if your in Sydney it will arrive either that day or the day after.
http://www.ppcco.com.au//enamel1.htm
As it says it takes a day or so to dry and subsequent coats need to be done after 6 hours I think.
So... I'm Seifer
PostPosted: Mon Jul 25, 2011 7:08 pm
Harts paint in Johnson st southport have it the next time you are at the coast Lachie
PostPosted: Mon Jul 25, 2011 7:23 pm
MPA paint supplies at thorneside stock POR15 products, Pretty sure its not off the shelf so might need to give them a call and check.
Simplify and add lightness
PostPosted: Mon Jul 25, 2011 7:46 pm
Forget brands. Paint is pretty much paint when you put it on a sandcast engine block...
Preparation is all. Clean, a light spray of etch primer and a couple of light coats of enamel/acrylic. It will last past your attention span - 20 years at least :)
Cheers, Ian
PostPosted: Mon Jul 25, 2011 7:49 pm
Por15 will not hold up against brake fluid..
you need to wear gloves and a respirator as it will not come off skin when dry and will give you a mean headache ..
stays on unless there's brake fluid involved
PostPosted: Mon Jul 25, 2011 7:54 pm
arh thanks guys :)
I thought POR15 was meant to be the paint that will hold up against brake fluid and the tougher of paints?
I certainly want to get something that will fight brake fluid after my recent experiences..
If it works good, I will also be using the same paint (different colour) to paint the inside of my engine bay..
Can someone tell me am I getting mixed up with another type of paint that fights the brake fluid?
If I could get something that fights that, well than it will take most things I hit at it,, ive found brake fluid to be the harshest thing in my "bay" :P
PostPosted: Tue Jul 26, 2011 12:22 pm
they say it will resist brake fluid.. may be a couple of times but its not what i have experienced.. I had to repaint my transfer cash after a spillage
I would still use it mind you on engines, etc but 2k on engine bays etc..
I have just gone thru this to repair my engine and engine bay after the fire.
Hope this helps
Ta
B
PostPosted: Sat Jul 30, 2011 9:22 pm
just a quick update for those interested, aftering having a good think about it, my budget, my wants, and talking to some people, I've decided to go down the 2 pak department.
Visited the lovely MrFail tonight and had a chat with quantities and colours for what I want to do. Should be all go ahead very soon :wink:
Users browsing this forum: No registered users and 72 guests
