It is currently Sun Aug 17, 2025 5:08 pm
PostPosted: Fri Dec 30, 2011 9:38 pm
adios57 wrote:
Look at the draught tube on the top one. No curve or move upwards just to even try and return oil vapour to the sump, just straight down.
When it starts to blow oil it just drops out and straight down.
Oily road.
Go downhill and empty the sump.
New rings every 30000?
It's the std Morris Minor 1000 setup. All 850s were like that too.. :wink:
PostPosted: Fri Dec 30, 2011 10:56 pm
GR wrote:
Hi Hagar
The engine number on this motor is 9m/u/h/
Graham Russell
That's the same as mine - 948cc High compression unit (not that I've ever seen a Low Compression one)
Short of whipping off the sump and having a poke around, I've no idea what the bump's for. My completely uneducated guess is that it's just a casting bump, possibly related to the earlier 803cc oil filter mounting, but with no internals behind it.
1958 Morris Minor 1000 - "Nigel"
PostPosted: Sat Dec 31, 2011 8:56 am
GR, have another reply for you
Have had a few thoughts on this motor. So here is a therory but just that a therory.
During the late 1950's and early 1960's John Cooper used the "A" Series engine in their Cooper Climax Formula Junior Cars ( under 1000cc's).
These engines were dry sumped and had a scavenger pump fitted driven off the camshaft.
I was fortunate to purchase one of these " works" camshafts back in 1960 when I owned and raced a 997cc Cooper Mini. The camshaft had two drive gears one for the distrubutor and one for the pump in line with the oil filter.
Then again I could be totally wrong.
John B.
Yesterday is history, tomorrow a mystery
Today is a gift thats why it is called the present
frosty
morris minor community forum
http://www.morrisdownunder.com
PostPosted: Sat Dec 31, 2011 8:58 am
Hagar wrote:
GR wrote:
Hi Hagar
Graham Russell
The 803 A series had the bypass oil filter on the other side of the block if I remember correctly.
PostPosted: Sat Dec 31, 2011 9:08 am
John B.
that extra gear on the cam-shaft was used through the fuel-pump hole as both a pump-drive & a cable driven taco take-off, depending on what you wanted it for
i have a few of those cams here
PostPosted: Sat Jan 14, 2012 5:06 pm
So Graham .... whats the answer ??????????
frosty
PostPosted: Sun Jan 15, 2012 7:02 am
Oh dear, worry, worry...
Hi Frosty
No answer yet,has a lot of people stumped, still asking the question maby some one will come up with the answer :)
GRaham
PostPosted: Sun Jan 15, 2012 8:55 am
Used for dry sump pump
PostPosted: Mon Jan 16, 2012 3:18 pm
I'm 99% sure that 803cc Minor engines had a spin-on oil filter up high on the front of the block, below #4 piston, like a late A+. Can't find a picture though
so I don't think that's it
edit:
hang on - maybe I'm only partly right - maybe it's a spin-on, but in the normal spot
http://www.motorbase.com/uploads/2010/0 ... ris1_8.jpg
