It is currently Sun Jul 27, 2025 3:01 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Sep 27, 2012 7:58 pm
JC wrote:
Mokesta wrote:
Would it help to also put up the teeth count for the pinion and crown wheel? That may tell people if it is an S ratio diff.
How do I determine that?
Put a paint or chalk mark on the pinion and the crownwheel, rotate whilst counting em.
You can see the crownwheel looking down into the diff from above.
PostPosted: Thu Sep 27, 2012 8:35 pm
The Mini King
22G232 Is the early number for cooper s MkI lay or cluster Gear It was later superseded to 22G1100
PostPosted: Thu Sep 27, 2012 8:53 pm
My book says Cooper S.
PostPosted: Thu Sep 27, 2012 9:26 pm
What's that prove? My S box has a 3.1 ratio (and pot joints) in place of the original 3.44 with Hardy Spicers; it only takes an hour or so.... The other one has a 3.76 with rubber unis...
Umpteen years ago one could not get a replacement S box without trading in one of the same. The valuable bit was the laygear of which there were two types; one stamped ME somethingorother (for a 4 synchro Mk II) and I've forgotten the original number on the other.
The early case was a 333 but unfortunately its still together so I can't look for a laygear label.. 22G1128 is a (maybe not exclusively) Mk II S case number.
Cheers, Ian
PostPosted: Thu Sep 27, 2012 9:42 pm
JC wrote:
15/64
Which book?
15/64 is 4.26:1 (same as a Morris 1100), it wasn't native in a Cooper S. But may have been a homologated option for competition use.
PostPosted: Thu Sep 27, 2012 9:43 pm
tasti wrote:
I thought all the early mk1 s boxes had the 333 case while the very late mk1 transitional boxes were 22a therefore it should have the hardie spicers with the 22a identification.
Correct! All 22A cooper s boxes had hardy spicers and no rubber unis!
1071 S wrote:
What's that prove?
It proves that I counted 15 teeth on the pinion and 64 on the crown wheel and my book says that's a cooper s. Which is exactly what I said, which is ALL I said. Hopefully it proves I can count, read and post my findings.
PostPosted: Thu Sep 27, 2012 9:48 pm
JC wrote:
15/64
Which book?
Bottom one shown as optional
PostPosted: Thu Sep 27, 2012 9:51 pm
JC wrote:
JC wrote:
15/64
Which book?
That askerisk * there applies to all those ratios below it- std on 1275S was 3.444.
PostPosted: Thu Sep 27, 2012 9:57 pm
Can you clarify what you're saying her Doc?
PostPosted: Thu Sep 27, 2012 10:54 pm
No 1275 Cooper S was sold here with anything but a 3.444.
So, IMO it's incorrect to say a 4.26 diff is an `S one'.
More so considering this book is not an official BMC publication (but it is a damn fine manual for Oz Minis).
That bottom list of ratios shown is just what was available over the counter as spare parts.
However after 40+ years, any box including yours and mine could have any diff in it.. :lol:
PostPosted: Fri Sep 28, 2012 7:34 am
Wow, that's a brave statement :wink:
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Fri Sep 28, 2012 7:58 am
So the casing points towards it being an S box.
They Laygear points towards it being an S box.
From what I read the diff that is in it looks like an 'option' for an S box.
Is there any other way I can confirm or deny?
My intent is to ensure I am not misrepresenting this thing.
PostPosted: Fri Sep 28, 2012 9:03 am
Alright no Oz built Production S built for the public then.
I'm aware Manton etc could get whatever they wanted... :P
PostPosted: Fri Sep 28, 2012 11:05 am
The Mini King
I would describe this as A three speed Syncro Gearbox With Cooper S MkI gears
Except for final drive, that is not a lie and it should put and end to arguments,
a lot of Police minis ended up with non original cases because the original case may have been damaged (idler gear bearing, silent Cops Etc ) they were repaired with parts from P.A Division and new cases had no serial numbers,
I supplied good second hand cases In the early days to dealers on many ocasions because new cases were not avail at the time,
