It is currently Tue Jul 29, 2025 12:11 am
PostPosted: Fri Jan 04, 2013 4:45 pm
I've started on a rod change box now. How do I lock the gears in one of them?
PostPosted: Fri Jan 04, 2013 6:15 pm
Remove diff housing,
remove detent ball spring and sleeve from under RH side cover,
rotate the selector inside anti-clockwise to clear all the bellcranks,
use a screwdriver to push the outer synchro sleeves into 1st and 4th gears from above.
PostPosted: Fri Jan 04, 2013 7:10 pm
Sweet got it, thanks.
