It is currently Fri Jul 18, 2025 1:47 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Mar 22, 2004 4:04 am
something tells me you should take a new water pump for sure.....
i was cruising in my old 850 (back in 1998) and the pump let go for no reason.... got SO hot the block was smokin, and kept running after i took the key out.... so after it cooled, i changed the pump and drove it away like nothing went wrong....
all the coolant pumped out thru the little hole on the underside of the water pump. Not sure if this hole can be blocked off / plugged to temporarily fix it though....
PostPosted: Mon Mar 22, 2004 6:58 am
I'd also fit a new 13lb radiator cap, make sure fan belt is OK, & take a spare.
If your gauge is electric, it should have a wire from ign circuit as well as the other 2 you mentioned. Maybe it fell off... :wink:
PostPosted: Mon Mar 22, 2004 8:57 am
That lil hole on the bottom is a warning hole, when the water starts to leak out of there, its time for a new pump... it starts leaking because the carbon/seal has warn down so far... and it begins pee.....
Thought I might post that... incase someone else is wondering why their water pump is leaking from there!
-Cam 8)
PostPosted: Mon Mar 22, 2004 9:24 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
yeah sure buy a lectric one and then find that the sender is wrong (you know there are different value senders right?) cappialary is alot more accurate 42 bucks for a pricol one and if buying thermostates don't buy cheap indonesion ones buy quality parts if you buy cheap parts and something stuffs up you only got yerself to blame
makka
PostPosted: Mon Mar 22, 2004 9:47 am
makka
nothing wrong with buying cheaper parts nowdays. They all have warranty of some sort, so if it stuffs up within 6 months, you just take it back and get a newie ....simple really
PostPosted: Mon Mar 22, 2004 7:32 pm
I'd take a waterpump as well, last week when we put another engine in my red' 78 , we were just about to lower the engine into the engine bay , when water started coming from "that little hole in the bottom of the waterpump", so my mate who is a mechanic said it was no good so we replaced it before fitting the engine. Tony :D
PostPosted: Mon Mar 22, 2004 7:48 pm
cept a warranty on a part that failed in the middle of nowhere doesn't help me.. coz i can't get anywhere to change it over :s
about the temp guage thing i just bought a splitfire temperature guage about a month ago, i sold it to my mate, but he's coming along for the ride to melbourne so i'll be able to chuck it on even just for the cruise over and back.
PostPosted: Mon Mar 22, 2004 10:42 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
also the cheap part you put on will only be replaced. not the other bit's it **** ,like just say the thermostat dont open what can we get from that ,well lets see cracked or warped head craked block yeah i'm sure the company you bought that cheap part of is going to say hey yeah mate here is a new motor for your car cos our part ****ed up ....
more than likly they will say did a mechanic fit it no oh well mate to bad your problem not ours
makka
PostPosted: Mon Mar 22, 2004 10:43 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
oh yeah and the split fire gauge should be ok but as i said the pricol gauge i had in my mini worked perfectly till i broke it :)
makka
PostPosted: Mon Mar 22, 2004 10:46 pm
min13k wrote:
also the cheap part you put on will only be replaced not the other bit's it **** like just say the thermostat dont open what can we get from that well lets see cracked or warped head craked block yeah i'm sure the company you bought that cheap part of is going to say hey yeah mate here is a new motor for your car cos our part ****ed up ....
makka
what the?
lay off the weed..or better still, share it round so we can then understand your language :P
PostPosted: Mon Mar 22, 2004 10:49 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
jon you calling me a drug addict ???
i really hope not as i find that offensive ...
and i'm quiet seriouse if buy a part and it **** up and is not installed by a "profesional" you really have no come back
makka
PostPosted: Mon Mar 22, 2004 10:51 pm
me not understand what u are saying, please explain :shock:
GTi Turbo'd mini, abused daily
PostPosted: Mon Mar 22, 2004 10:55 pm
makka
you took offense to what I said? lmao, drugs are messing with your head man...
PostPosted: Mon Mar 22, 2004 10:58 pm
makka
oh for christ sake man... quit being so serious!!! 8)
if u wanna write your posts in INGRISH then go right ahead.. but dont expect anyone to understand them. :?
try putting some punctuation in occasionally.. and maybe try that funny L shaped key... you know.. the [Enter] key!!! :lol:
Lighten up!!!! :roll: :P
...its leaking oil... and thats a good sign!
It lets me know that I havent run out yet. :P -Tzi 4-9-04
PostPosted: Mon Mar 22, 2004 10:59 pm
Hey makka is your comma key broken mate? u know the tear drop thing next to the letter M? m is next to n if that helps :P a lot of people use it to create breaks in there sentances so they dont have to read like this non stop therefore creating a whole heap of meaningless words :roll:
Users browsing this forum: 1071 S and 97 guests
