It is currently Sun Aug 03, 2025 1:56 pm
PostPosted: Sat Apr 20, 2013 12:58 pm
TheMiniMan wrote:
they are a tad stronger in a sense,,, they`re designed to share the load better across 4 planetary gears instead of the std 2
& they also (inherant in the design) share the load across 2 pins instead of the std only being one cross-pin
so yeah they have a value for street use for sure... & are pretty well priced really compared to the cost & time & energy & & & attempting to fully overhaul a std diff,,, even trying to find a good condition std carrier is hard these days so , i think the 4-pin is good value
if you were going to do any track days then i`d suggest a Quaiffe diff
All too true Matt, but they do have a weakness. The planet gears in these don't have a full spot face to seat against (they are churned out on CNC :roll: ) so they only have 2 lines of contact and the pressure on the gears is at 90 degrees to that contact. It seems they are made to test the planet gears in a way for which they were not designed to work! I've seen these diffs split planet gears no problem.
PostPosted: Sat Apr 20, 2013 3:56 pm
yeah i understand the problems associated but for a roady they "should" be fine
we all know the design isn`t perfect & yes the material they use also could be far better :-)
but hey? do we all now fit Quaiffe diffs into our roadys (i know i do) :-) but still not everyone can afford a quaiffe , not everyone wants a quaiffe, & not everyone wants to stuff around trying to sort-out a good std diff either :-)
what do you do>?
dont worry about the mini diff & just stick a turbo charged alloy V8 into the back of an MR2 instead :-)
PostPosted: Sat Apr 20, 2013 4:59 pm
The Mini King
1380 K wrote:
Okay cool. I've found a s ratio lay gear but I don't have the first motion s ratio shaft. Anyone know he avalibility of these for pre a plus boxes? Also what are the advantages of a cross pin diff for a road car?
You can have Your 4spd Main shaft ground to suit A plus top Gear
See Doctor Kev
PostPosted: Sat Apr 20, 2013 6:21 pm
Yes,
or
TheMiniMan wrote:
what do you do>?
Make a decent one
PostPosted: Sat Apr 20, 2013 6:40 pm
yeah alright smarty pants, you win this round,,, but i`ll.....
Hey nice diff mate :-)
PostPosted: Sat Apr 20, 2013 6:53 pm
Didn't know it was a competition!
Cheers for that :)
