MiniBill wrote:
I got an email from karcraft this morning mentioning standard drums and wide drums to suit flares , which has me a little confused.
Will standard drums with A08's fit under my gaurds " no flares needed " ?
And is there any benefit from the wide drums over standard ?
Cheers Bill
The `wide' aka spacer drums are same as Cooper S rear ones. They will give you the same track as a Cooper S. Were used front & back on Clubby S (which all had flares).
Whether legal without flares depends on the wheels. eg LS offset Contessas would be fine, standard Mini offset Contessas would not.
Internally, the drums whether `wide' (spacer type) or not are all the same diameter & width.
Thanks Kevin as always your expierence and knowledge are invaluable to myself and many others here , so thank you very much.
drjbeam wrote:
Dearest parts on brakes are the back plates and the spings that go on the front wheel cylinders
If your gonna use the plastic .700 master cylinder get the 15/16 wheel cylinders as 1' wheel cylinders dont work the best on a .700 master cylinder
I changed every thing from the master cylinder down
Im just waiting for the handbrake levers smu10005 <a> have they come in mr karcraft they were on back order they there yet
Thanks yeah i have the plastic ones will go the 15/16 then
Thanks for all the hey guys its greatly appreciated.
Cheers Bill
Project Pickles is ALIVE!!!!!
Click Here!
