It is currently Sat Aug 02, 2025 12:51 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Sat Mar 01, 2014 9:17 am
While I haven't got around to hooking up speedo cable this might give you some ideas of how to attach speedo to airbox,I made a couple bracket to allow you to attach using four screws on the front face.
I wil take a picture of actually brackets later on today for you.
Mal :D
PostPosted: Sat Mar 01, 2014 4:34 pm
air box brackets for speedo
You will need to slot botton of center binacle
Hope this helps . Mal :)
PostPosted: Sat Mar 01, 2014 5:11 pm
Thanks Make. What are the dimensions of your box, particularly the depth. Also what Suze is,the manifold. My hope is to tick it all behind the binnacle, packing it out only slightly if required.
PostPosted: Sat Mar 01, 2014 10:19 pm
The manifold is 3 1/4 , box is 130 deep at bottom, 30 top. 275 wide and 200 high. Designed to allow as much air flow as possible around intake, hence extra clearance around K&N filter.
M :)
PostPosted: Mon Mar 10, 2014 4:00 pm
It's happening!!!!
PostPosted: Mon Mar 10, 2014 4:31 pm
Looking good, its making me consider very hard whether to renovate my firewall!
PostPosted: Mon Mar 10, 2014 6:51 pm
It's coming along nicely.I've hopefully found a balance between depth and fitting every bloody thing in behind the dash.
PostPosted: Sat Mar 22, 2014 7:13 pm
Box is now in the car and the binnacle appears to want to fit too. Pics to come.
PostPosted: Sun Mar 23, 2014 9:10 am
Good stuff, can you take a couple of the engine bay as well as inside?
PostPosted: Sun Mar 23, 2014 5:10 pm
Binnacle does not want to fit it now appears. Will now be packed out slightly.
PostPosted: Mon Mar 24, 2014 3:03 pm
So the binnacle is packed out slightly, sitting just on the bottom rail. Some cosmetic work involved but the result is overall quite neat. Here's the box installed.
