It is currently Mon Jul 28, 2025 3:40 am
 Post subject: Re: A+ Distributors
PostPosted: Sat May 10, 2014 10:04 am
Accuspark are now selling a new 59D dizzy and stealth box combo-
http://www.ebay.com.au/itm/Fully-progra ... RTM1430835
Price not bad if you need a dizzy too.
PostPosted: Sat May 10, 2014 10:11 am
Looks like a good setup Doc. Would it be a suitable option (with a different dizzy for A-) for a daily driver 1100?
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat May 10, 2014 10:14 am
Yes, should work fine.
I am doing one for my 1360, am using my 45D, with a simonBBC module from UK, and the Stealth box bought local, see links above.
I will use my dialback timing light/tacho to plot what curve I have now with the pulsar dizzy in. Then I'll load that map for starters.
PostPosted: Sat May 10, 2014 10:22 am
Sounds good. 45d, is this the one that I should use? Are the specific ones for small bore and large bore?
5/72 Clubman Gt
PostPosted: Sat May 10, 2014 10:49 am
45D was used on most Minis here from mid 70s, 998 and 1275. You can still buy caps etc, which you cannot for the earlier Aust made 29D.
Any 45D will do if you are going to fit the Stealth box, as the internal advance gets locked. You then program the advance curve. See the other thread on the Stealth box. viewtopic.php?f=2&t=83483
