It is currently Sat Jul 19, 2025 12:56 am
 Post subject: Re: Moke Shells
PostPosted: Wed Oct 14, 2015 7:54 pm
One lives in Melbourne.
It is owned by one of the members of the moke forum
PostPosted: Thu Oct 15, 2015 9:37 am
peterb wrote:
so if you were to replace the rusty panels with stainless ones, would that work?
Technically you could weld stainless patch panels into the mild steel body, but it wouldn't be a good idea. You'll get weird corrosion problems from dissimilar metals. Also stainless is not really that good for car bodies (even Deloreans only have a skin of it over plastic panels). There are many different stainless alloys, but typically they tend to fatigue and work harden more readily than mild steel, so will crack easily.
Zinc coated mild steel, like the factory used toward the end would be much better.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Oct 15, 2015 7:33 pm
Sorry to disagree, stainless is terrific stuff providing you use the right grade.
There are no issues welding stainless to carbon steel.
Have a look at all the stainless steel trains running around.
Phil
PostPosted: Fri Oct 16, 2015 8:43 pm
Happy to be corrected. What grade of stainless would be suitable?
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Sat Oct 17, 2015 6:55 am
Wouldn't that be Strainless steel? Apologies for poor humour.
PostPosted: Sat Oct 17, 2015 9:49 am
You use something like a 309L wire for welding 316 stainless steel to mild steel, so that the weld metal (which is a blend of the filler and both parent metals) ends out with enough chrome in it.
PostPosted: Sat Oct 17, 2015 10:39 am
Gould old common 301 grade will suit most applications.
As above, weld the stainless to carbon steel with stainless wire and all should be good !
