It is currently Sun Aug 03, 2025 11:46 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jul 19, 2005 8:44 pm
For those who want to remove it, it sits in top of the MC. In the end of the spring. Last bit that falls out. :wink:
 Post subject: yep
PostPosted: Tue Jul 19, 2005 8:55 pm
Doc is right and just maybe instead of removing it a new kit and check of the mater should be made as the presure required for discs is much greater than drums and any wear or even slightly dodgy seals will soon show up with discs and it might save you the hassle of having to remove the master twice, might even save your life
 Post subject: Re: master cylinders
PostPosted: Tue Jul 19, 2005 9:43 pm
feralsprint wrote:
basically they are the same but in the drun brake cylinder there is an extra seal to stop the return of fluid back to the tank
This seal has a hole in the centre of it. Do you really need to remove it?
 Post subject: simple answer
PostPosted: Tue Jul 19, 2005 9:55 pm
YES if you have discs
PostPosted: Tue Jul 19, 2005 10:00 pm
Thanks for all the info. I will get new wheel cylinders and remove seal and see I get on then.
Pete
PostPosted: Tue Jul 19, 2005 10:18 pm
If you have just fitted the brakes wait for the to bed in....also did you taje the shine off the pads :shock:
PostPosted: Tue Jul 19, 2005 11:02 pm
What this seal does is restrict the flow back to the MC. But if you have discs this will prevent the seals from flexing the pistons back off the discs properly.
Not good... so pull it out!
PostPosted: Wed Jul 20, 2005 8:03 am
Going to take seal out today. The pads had a rough surface with no shine (brand new from HMG)
Pete
PostPosted: Wed Jul 20, 2005 8:36 pm
Took the seal out today, noticed before I did the inside pads on both sides were still hard up against the disk. After taking seal out took it for a run brakes are better ( I think they have bedded in now ) and the inside pads are away from the disk. Am going to put the cooper s wheel cylinders in tomorrow all things going well.
Pete
PostPosted: Wed Jul 20, 2005 8:47 pm
glad it is all working out for you, some of the stuff they taught us in the 70s still comes in handy and not much has rally changed in the world of mini's
PostPosted: Wed Jul 20, 2005 8:51 pm
Just thinking on the keyboard.. :? I wonder do these new MCs with the plastic tanks have that valve in there?
Anybody had a look? :lol:
