It is currently Wed Jul 23, 2025 12:36 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Feb 16, 2007 7:56 pm
Depending on the year of manufacture, there can be up to three brown wires on the starter solenoid. For one with two wires, one will wire directly to the alternator and the second to the fuse box, ignition switch and light switch, The second brown wire, therefore, if it is in the condition you state, can be very troublesome and quite possibly the source of all your trouble ie: lights and gauges failing, alternator not charging etc etc..
If I come over tomorrow, I'll bring everything we need to check and fix any problems with your wiring, timing and alternator. Give us a call when free.
David
PostPosted: Fri Feb 16, 2007 9:30 pm
I is a mookenik
yeah dude dw ur not the only one, today i found out i have a problem with mine as well. when the car is at idle the alternator wont charge i need to actual rev or drive for th alt to work
PostPosted: Fri Feb 16, 2007 9:37 pm
mine charges very slowly so after few minutes of driving it stalls and runs out of juice
ending up with very weak battery or flat
PostPosted: Sat Feb 17, 2007 12:37 pm
David, will try replacng my alternator 1st and will let you know if I'm still having problems
Might go down to the local wreckers and see what I can find regarding the lower bracket for the EA alternator
PostPosted: Sat Feb 17, 2007 8:40 pm
Rob
I do have spare alternators that I could bring over if you have trouble getting one.
PostPosted: Sat Feb 17, 2007 9:34 pm
Razor, it seems that you have been in trouble since you changed the starter.
On the original solenoid where you joined the cable from the battery to the cable to the starter is the brown wire on the same post or the other post?
PostPosted: Sat Feb 17, 2007 10:08 pm
The brown power wire for the alternator is on the same post with the starter motor
David I've got an EA to try and install, if that doesnt work then might try your alternator, but it should work.
I've got a bracket today and will try installing the alternator tomorrow.
