It is currently Sat Aug 23, 2025 1:34 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Jul 16, 2007 9:04 pm
Heh... at least we HAVE indicators, not those stupid electromagnetic lift-up trafficator arms like Morrie Minuses and VW beetles etc did. :lol:
My A30's both had trafficators. Geez they made a noise when they popped up.
PostPosted: Tue Jul 17, 2007 1:18 pm
Drewus wrote:
Does anyone else experience other drivers not being able to notice the front indicators flashing whilst you have the headlights on at night?
The number of times i've almost crashed into someone because they don't LOOK properly (guess their just used to seeing flashing orange) is amazing.
I've also been harrassed by people because they don't think i've indicated.
This is a problem that has bugged me for quite some time. It's no surprise that they don't see the indicator flashing when the headlights are on as basically your indicator is the clear parking light flashing brighter. That's basically impossible to see!
One solution would be to fit H4 headlights with a parking light attachment and unplug the original parking light, then the flashing indicator would be much more obvious. This is what I'm planning on doing and is actually how 850s in the UK were originally and had an orange flasher lense.
Don't blame the other road users though, so sometimes they look and see nothing or don't look at all. It's up to us to make ourselves seen and never assume that other road users have seen us.
PostPosted: Tue Jul 17, 2007 10:09 pm
Anto, is the process to get the parking light attachment going as simple as a plug in and away you go job? I'm no auto electrician.
PostPosted: Wed Jul 18, 2007 6:35 am
minivanman wrote:
But at the same time I only pull out if the other car is doing the legal left turn signal to leave the roundabout (including straight through) or can judge by their speed that they aren't coming round with no indicators.
Not as easy on small roundabouts (nearly every intersection in E.Suburbs where I live for example ) especialy when youre facing a Sydney cab driver who got his licence yesterday and has been at the wheel for 11 hours now and so will ignore you unless you are flashing like a fire truck or untill he's gone through your left door.
PostPosted: Wed Jul 18, 2007 1:05 pm
A little bit involved but not too hard. Basically you will need to remove the parking light wire from the current light and connect it up to the new bulb in the headlight. Probably not plug & play as you may need to extend the wire a bit and change the connection on the end (it will currently be a bullet connector and you will need a spade). You will of course need to buy new headlights to get ones with a parking light in them. Not expensive and you will also get much better H4 lights in the process. PM me if you want details.
PostPosted: Wed Jul 18, 2007 6:28 pm
I have good soldering experience, so anything involving that shouldn't be a problem.
Users browsing this forum: Bing [Bot] and 291 guests
