Anto wrote:
As the person in that thread that suggested use of WD40 and a BFH, I completely and utterly stand by that advice. In my recent experience of doing that job, that was what I did and it worked.
In regards to damaging the thread of the pin, that is a valid concern. However, I would argue that when the lower control arm pin has rusted to the bush insert, it is generally no longer usable anyway - every time I have come across this situation, that has been the case. The pins are available new.
I would take offence to any suggestion my advice is crap.
In this case, i reckon it was a bit of advice that was valid. But it was incomplete. If you had also said "In regards to damaging the thread of the pin, that is a valid concern. However, I would argue that when the lower control arm pin has rusted to the bush insert, it is generally no longer usable anyway - every time I have come across this situation, that has been the case. The pins are available new" then it would have been complete.
Burning the rubber away was also valid, and may have salvaged a usable part.
The point is, a lot of people are giving incomplete or misleading advice, without regard for what someone else may do once they read it.
So if we all temper our enthusiasm for the BFH with moderation and a guiding hand to the amount and severity of said BFH application to the task at hand, we will provide better advice!!
Still a good call I think.
M
