It is currently Tue Jun 24, 2025 7:43 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu May 29, 2008 11:59 am
Forum Graffiti
Blokeinamoke wrote:
BFH swung TBH
:lol: I like that! :lol: Yeah, in all seriousness, people have to use a little common sense... If someone has said 'use a BFH to get the little skinny, frail pin out of somewhere,' common sense would tell you 'Hey, that might break!' :roll:
The BFH and matching screwdriver are probably some of the most used tools in my chest :D
Just don't bash the shiz out of things that will obviously break... :roll:
PostPosted: Thu May 29, 2008 12:34 pm
It's not just breaking things that is an issue, it is also rooting them.
A recent thread was talking about bashing a lower suspension arm pivot bolt out, the only part of this that is remotely bashable is the thread on the end. Hit the thread a few times, stuff the thread up, the part is buggered but not broken. In this case the original answer of melting the rubber out was the best one, I've been there and done it, but the BFH brigade got in there and it seems the question asker used force as the option.
I've used the BFH as an example, what I'm referring to is crap advice in general.
It just seems to be against the reason for having a forum, that is to help impart information and knowledge. We can all learn something but it is pointless teaching the unknowing the art of destruction :!: :!:
Steve
PostPosted: Thu May 29, 2008 1:58 pm
As the person in that thread that suggested use of WD40 and a BFH, I completely and utterly stand by that advice. In my recent experience of doing that job, that was what I did and it worked.
In regards to damaging the thread of the pin, that is a valid concern. However, I would argue that when the lower control arm pin has rusted to the bush insert, it is generally no longer usable anyway - every time I have come across this situation, that has been the case. The pins are available new.
I would take offence to any suggestion my advice is crap.
PostPosted: Thu May 29, 2008 2:03 pm
Sometimes belting the shitter out of something with a BFH is the right advise. Maybe further detail should added to ensure that the correct is used. eg with a light fairy tap gently with a BFH motivate the pivot to move or applying medium effort, ensuring the thread is preserved, apply the BFH to the pivot as you would a badly behaving child.
PostPosted: Thu May 29, 2008 3:11 pm
:lol: another classic
finally own one :D
PostPosted: Thu May 29, 2008 3:42 pm
In this case, i reckon it was a bit of advice that was valid. But it was incomplete. If you had also said "In regards to damaging the thread of the pin, that is a valid concern. However, I would argue that when the lower control arm pin has rusted to the bush insert, it is generally no longer usable anyway - every time I have come across this situation, that has been the case. The pins are available new" then it would have been complete.
Burning the rubber away was also valid, and may have salvaged a usable part.
The point is, a lot of people are giving incomplete or misleading advice, without regard for what someone else may do once they read it.
So if we all temper our enthusiasm for the BFH with moderation and a guiding hand to the amount and severity of said BFH application to the task at hand, we will provide better advice!!
Still a good call I think.
M
PostPosted: Fri May 30, 2008 4:00 am
most commonly misused tool is the one between yer ears.
most common mistake is not asking what seems to be a stupid question.
all advice given is free, and so you must consider it in this way. you can't get your money back :roll:
most advice is offered from years of hard gained experience and you should read it with the patience that it deserves.
and keep using the tool between yer ears.
PostPosted: Fri May 30, 2008 11:59 am
here here :wink:
PostPosted: Fri May 30, 2008 12:13 pm
you are assuming that people are actually the tool between their ears :?
PostPosted: Fri May 30, 2008 6:16 pm
or perhaps the act of using the little head rather than thinking with the big head :wink:
PostPosted: Fri May 30, 2008 7:00 pm
If anyone is sceptical of the advice given , ask more questions, or maybe a please explain?
Its not so much about the wrong advice its about asking the right questions.
blokeinamoke wrote:
PostPosted: Fri May 30, 2008 7:16 pm
Resident Haemorrhoid
well obviously they can be used as a precsion instrument see third Pic :wink:
see below
cooper69 wrote:
Hi All
I have nearly completed my Electric Mini Matic. Here are a few pics, let me know what you think!!!
Motor/gearbox ready for installation
Motor/gearbox in car
Car with motor installed
Controller and accesories.
Cheers Phill
heres the thread
http://www.ausmini.com/forums/viewtopic.php?t=42150
mtsmini wrote:
Tombo wrote:
PostPosted: Fri May 30, 2008 8:33 pm
see below
cooper69 wrote:
Cheers Phill
Thats a SFH!!! :P
On a serious note I have been struggling to free parts and thought that there still must be a bolt in there somewhere only to be given the BFH advice. That has saved a lot of time stuffing around. Mind you I didn't pick up my biggest sledge and give it 11/10!! :shock:
As said previously, the advise needs to be taken in context. :roll:
Some people just have to break some parts before they learn. I'm sure everybody who has takled big jobs on their cars have F**ked up every so often and thought: "well I won't do it that way again!" :wink:
-James.
Toyota 4EFTE Powered Minivan.
Users browsing this forum: TartanRed and 94 guests
