It is currently Sat Aug 16, 2025 1:55 pm
Post new topic Reply to topic  [ 223 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 15  Next
PostPosted: Fri Aug 13, 2010 3:05 am
Use NGK CR9EK's, or Denso U27ETR's
it make the indexing much less critical.
http://www.sparkplugs.co.uk/pages/database/compare-spark-plugs-ccp.asp?partno=CR9EK&alternative=U27ETR
PostPosted: Fri Aug 13, 2010 11:22 pm
Those plugs wont work as the head is designed to use an ER9EH plug, thread dia of those plugs is 8mm.
Now with 2 extra ports!
PostPosted: Sat Aug 14, 2010 1:51 am
8mm! that tiny!
PostPosted: Sat Aug 14, 2010 8:08 am
I am liking that head. This may be enough for me to put an A series engine in my mini!! It was the cost of a cross flow head that pushed me towards engine conversion (with 5 speeds, ligher, 5 bearing crank, overhead cams.... ) in the first place.
I'd inject it and not get the Webers I reckon.
M
PostPosted: Sat Aug 14, 2010 9:36 am
I remember enquiring about a X-flow head back in about 1985 and was quoted $2000 I only paid $1800 for my Cooper S in 1982
This whole setup is a real bargain, I just saw a weber and manifold on Ebay for $1000
PostPosted: Sat Aug 14, 2010 9:56 am
Can anyone tell me if you can fit this head to a 1098 bottom end?
What size are the combustion chambers?
Jason 8)
PostPosted: Sat Aug 14, 2010 9:58 am
With the realative ease of manufacturing and machining short production items these days, it is a golden age for custom heads 8)
PostPosted: Sat Aug 14, 2010 12:04 pm
Jason 8)
it'd be fine on a 1098, just need to pocket the block the same as for any 1275 head
combustion chambers would be same size as a 1275 too - 29cc?
PostPosted: Sat Aug 14, 2010 1:38 pm
Jason 8)
1275 stock chambers are 21.4cc Simon. :wink:
These would be similar.
PostPosted: Sat Aug 14, 2010 2:13 pm
These would be similar.[/quote]
yeah... close enough :lol:
PostPosted: Sat Aug 14, 2010 3:40 pm
So, if a bloke was to get one of these, who would he send it to for the best work?
Say that bloke also had an Eaton M45 supercharger in his garage, would that change the work required to the head? (Maybe chamber volume for compression but any difference in ports or valve seats?
M
PostPosted: Sat Aug 14, 2010 7:27 pm
Chambers on these heads are 24cc.
PostPosted: Mon Aug 16, 2010 1:25 pm
Just ordered my crossflow setup from same place. Tired of waiting for other alternatives. Looks like good value if you ask me. Inlet ports are plenty big enough, exhausts could do with some work and the guide bosses are a little large but in all should clean up well. Will let yall know how it goes. Thanks for the heads up (pun intended)
1962 Mini Speed sports sedan
PostPosted: Mon Aug 16, 2010 1:42 pm
M
that bloke might have a fun time making the inlet manifold - the end result could look very funky :)
PostPosted: Mon Aug 16, 2010 3:51 pm
So is that 4 [Edit: 5] of us with these already?
TK
Sitnlo62
awdmoke
lownblown
mokesta
I can't wait, but I don't have a car or bottom end!
Of the other 4 guys, who's getting who to do the porting work? I have only ever used Liddels in Brisbane over 10 years ago. PM me if the forum rules prevent a completely honest reply here.
WTB: 1 1275 engine (head optional :) ) and rod change gearbox.
M
Users browsing this forum: No registered users and 319 guests
